There are ISPs that block utorrent. I found this explanation of how to do port forwarding on the BT home hub, though:
http://portforward.com/english/routers/port_forwarding/BT/BTHomeHub/Utorrent.htm
So, all I can suggest is to open the ports on your home hub as suggested above and to connect your computer straight to your home hub rather than to your CWR-854 (unless you actually have no such router and just picked that to ask the question under).
It is possible that someone has decided that you should not use torrents (they slow down everyone because they actually have the nerve to use the internet) and they are associated with thieves. Not to mention that there are tons of legit uses for them,
This could be someone in your ISP or your house. So do you have access to everything? You can poke around with telnet - can you access the ports on the other systems that utorrent accesses to make itself part of the network of systems that are downloading and sharing the torrent?
But if one knows the ports it is easy to block torrent.
If you have multiple routers that do nat, the home hub has to forward to your router, not to your system. So if your router is 192.168.3.12 and your system is 192.168.5.6, the BT home hub has to forward to the port on your router, on 192.168.3.12 , and your router has to forward to your system on 192.168.5.6. If the home hub tries to forward directly to your system (if you have multiple routers, which you might have because of the way you asked your question) then it won't work since your router hides 192.168.5.6.
Can some one please help me change my router from strict to open please . And where can i find the router on my laptop so i can change it please
