Assuming that the model you have is a single speed transmission with variable speed belt system and that the mower has never been used to tow anything heavier than a dump cart. 9 times out of 10 its usually the forward gear shift key not allowing it to go all the way into forward gear. Might be able to ajd the shift linkage to acomodate a tighter mesh with the input and ring gear
The linkage is set correctly, I have ensured proper adjustment. All belts are in good shape, the sound sounds like it is in the trans. I think it must be something in the clutch system in the trans not allowing it to fully engage??
