Trying to install wireless network. Wireless network connection properties does not have "use windows to configure network" need a work around requirement for Netgear.
If you're using windows XP then you need to start the Wireless Zero Configuration. just click on the start button and choose run then type in services.msc in the run box and click on ok. in the services window just look for Wireless Zero Configuration, it's at the bottom part of the list. just double click it and under the General tab you'll see a box for the Start up type, just set it to Automatic and then on the Service status click Start and then Ok button. once you finish this, you will be able to see the Wireless network tab to be able to select the "use windows to configure my network". in case you're using vista, that option is actually not available as it automatically starts the windows wireless manager and only conflicts if there is a third party software/ wireless manager installed in your computer.
hope this helps...
Testimonial: "Thanks -- that solved the problem !"
I am sure what exatly you required but try this link, you will get better idea http://www.microsoft.com/windowsxp/using/networking/setup/wirelessadapter.mspx
the OS is XP
Thanks but that is the problem. When I go to the wireless networkconnection properties tab, the only tab available is the General tab. I have another computer running this wireless system and it has the General tab as well as a Wireless Network tab and an advanced tab. Under the Wireless Network tab is the "Use Window" box. However with the computer I am trying to configure, there is no place to check the "use windows" and the system will not set up an IP address.
Can you mention the OS|?
