Expert
- Posted on Nov 24, 2009
Re: Saying clear paper jam, I have done, there is no...
Clearing a paper jam in a Lexmark laser printer is an easy thing to do.
Laser printers produce high-quality products and are fairly complex
machines, but paper jams (in most cases) can be solved mechanically
with a little know-how and time. Follow these steps to learn how to
clear a paper jam in a Lexmark laser printer.
ep 1
Take the paper out of the paper trays. This will prevent any more paper from being drawn into the printer to further the jam.
Step 2
Remove
the cover from the housing of your Lexmark laser printer. This will
expose the inner workings of the printer, and you also should be able
to see the jammed paper.
Step 3
Pull gently on the jammed paper. In many cases this is all that is required; the paper jam should move out slowly and smoothly.
Step 4
Press
the flashing paper jam button. This will allow the rotors to turn
freely, which will facilitate the easy removal of the jam.
Step 5
Unplug
your Lexmark laser printer if the jam persists. This will allow you to
pull more firmly without the gears working against you.
Step 6
Examine
the inner workings and confirm that all paper and shreds of paper have
been removed. If the paper tore during the clearing, make sure none
remains or it will inhibit normal printer function.
Step 7
Plug the printer back in, refill the paper tray and try to print again.
- Make sure to use a printer and paper type that are compatible. Consult your owner’s manual and the manufacturer’s Web site.
- To deal with a large jam, it might be necessary to pull sheets from the middle of the jam in order to loosen the whole thing.
- Always
pull the paper “with the grain” of the mechanism, if possible. Pull it
through the printer the way paper normally travels so that you don’t go
against the gears.
For more serious repairs, contact an electronic store or professional repair person.
Testimonial: "Wow... thankyou so much for your speedy response, great I will give it a go."
