Nikon Coolpix 3200 Digital Camera Logo
Posted on Nov 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am unable to see all the photos on the camera after viewing the memory card on a laptop. They are still present on the card (85 files) but on the camera I get the message "File contains no image data" The only changes I made on the laptop were to change the view of approx. 10 files from landscape to portrait and save. Regards Andy
Anonymous
Level 3:
  • Master 2,335 Answers
  • Posted on Nov 24, 2009
Anonymous
Master
Level 3:
Answers
2335
Questions
0
Helped
882754
Points
4663
I can't tell you exactly why all your photos became unavailable on your camera, but I do know that many digital cameras as well as handheld media devices (zunes, sansas etc) are very fussy when it come to the images stored on them. They write index files describing what is stored on them, and yes, if your alter any files using a computer after they were imported and indexed, they will disappear from view on the device. I am surprised that all your photos no longer show up, not just the ones whose orientation was altered.
I recommend moving your photos to your laptop and using your camera to reformat your memory card. I am unaware of any way to coax them into being viewed on your camera once they have been shunned.
Unable view images computer
I need more detail about what you are doing though. Are you removing the card and placing it in the computer or are you connecting your camera to the PC using a USB cable? If it is just the photos you have on the card that are messed up, try to copy the photos you can see to the PC. Try to transfer them all to a folder on the PC. You may be able to recover your photos with software. You can download "Recuva" free at this site: http://www.filehippo.com/download_recuva .This software can recover corrupted files. You should have the memory card in a USB adapter connected to the PC for this software to work well. Your card probably needs to be formatted, using the menu on your camera, after you have recovered your photos. That is the most common cause of file errors in cameras. It is good practice to format you memory card fairly often after the photos have been removed. If you have a second card, try taking three or four pictures on it and see if you can access them okay.That would prove there is nothing wrong with your camera.
When i view my photos om my camera they are all there. But when i connect my camera to my laptop it open the window to view files but there are no files or photos available. But when i connect the camera...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
1helpful
Unable to view photos i have taken, Screen says Read Error
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
1helpful
2answers
I Have taken pictures with the camera , after it saves it keeps telling me photo error , im trying to recovery images i have taken , and they are unable to view and when i copy them to my pc , windows says...
Your pictures may be corrupted.You can recover those corrupted pictures with this
1. Do not save any new pictures into the memory card of your camera.
2. Insert the memory card into a card reader. Connect it with computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download recovery software, recommended one is Tenorshare Data Recovery (simply because i was using it and it worked)
http://www.any-data-recovery.com/product/datarecoverystandard.htm
4. Install and open the program, select your memory drive, and click 'Start' button to start scanning process which will find your deleted photos.
How to Recover Deleted Pictures from Digital Camera's Memory Card?
Pics gone in DCIM folder. Using a Nikon s3000 coolpix camera, connected to computer, F:\s3000 is detected, within it is DCIM folder present, and within DCIM folder presents Nikon100 and Nikon101 folders,...
You cannot create new folders on an SD card and copy images to them, as the camera will not recognise them, since they were not create in the camera. Copy the entire contents of the card to a folder on your HDD, then format the card in the camera.
1helpful
3answers
I was unable to download pics from my fujifilm 2gb sd card to my pc when full (using card reader), but unable to view photos and when put back into finepix camera now says card error so cannot view...
I have had success with this photo recovery program called asoftech photo recovery... Download the program
http://www.asoftech.com/apr/
You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
1helpful
Worked for some
hello,
what operating system are you using? 98se, Xp or vista?
the usb change on your camera to mass storage works good with XP & Vsta.
if selected, you wont see scanner and camera wizard ever again.
when pugging your camera into your pc, the autorun window pops up like you just plugged in a USB jump drive in.
on view file you can drag the whole folder onto your desktop from the camera and rename the folder once done.
if the photos are showing up unable to view photo, file could be corrupt.
ive seen bad memory cards do this. then try another card.
good luck.
2helpful
2answers
Unable to download pictures from camera to laptop
Your camera, memory card and laptop got infected with virus and should be scaned with updated anti-virus program.
There is some base memory on the camera, you may be writing to it instead of the memory card. To test this theory, remove the memory card and see if you can still view the photos.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
