Question about Maytag MAH2400A Front Load Washer
Nasty Noise when Maytag MAH-24 pumps-out
Loud grinding noise when washer is pumping water out.
  • 1 more comment
  • azfan Mar 02, 2008
    Having same problem. Sounds as if there is/are coin/s in the pump but after pulling off the front cover, there are no screws that form a square on the right side. The entire front cover is attached and riveted making it appear that it can only be accessed by removing rear panel on machine. I had fixed my HE2 pump from the front, but can't even find the pump on this machine. Anyone know exactly where to look/how to remove the pump?
  • dctreehugger Jul 06, 2008
    We had the same problem and followed the instructions to remove a quarter and a nickel from the pump. THANK YOU for the clear directions. It made fixing this problem a cinch and my husband and I were easily able to fix this ourselves w/out having to waste time and $$$ on calling a repair person.
  • laurahynd
    laurahynd Jan 18, 2012
    We had the same problem and found a quarter in the pump. Although our model had a few extra screws the images were very helpful for being able to identify the various parts. Thank you for not charging to show us this answer like other sites want to...we were able to do everything in under 30 minutes!
  • 125 Answers
Unplug the machine. Tip the machine back. Take the plastic cover loose from the bottom front of the machine. There are 4 screws on the right front side of the machine that form a square. Remove those and take the spring clamps off the pump hoses and wire connector. Whatever water that is in the machine will come out, have a bucket or shop vac ready. The coins or other foreign objects that are in the pump can now be removed. Hope this helps
Posted on Jan 13, 2008
  • Sasquatch103 Nov 07, 2010
    I would like to echo all of the reviews of benham. I had written off this washer prior to stumbling across this post. Instead of spending a $70 service fee plus who knows how much in parts and labor for a tech to come out, I found .35 cents in the water pump and now have an operational washer. Thanks!
  • rjo23
    rjo23 Jan 10, 2013
    I had success with these excellent instructions. One thing to add: check the pump outflow outlet. A nickel is the exact size as the opening and can get wedged in the outlet. It won't rattle or make noise to tell you it's in there.
Benham's advice is one of the most useful pieces of information that I've ever found on the web. I was envisioning big service $$, if not a dead washer, but following the steps, I was able to get out the quarter (and penny) in the pump. Fantastic advice!!
A few points, however.
1) You don't need to tip the washer entirely on its side, but you need to tip it enough that you can access the bottom of the washer.
2) It's not trivial to get the plastic cover off the bottom of the unit. However, if you fiddle with it enough, you'll eventually get it off.
3) My MAH2400 had five screws on the bottom, not four. That's a pretty obvious issue to deal with.
4) If the coins have been in the pump for a long enough time, it may have chewed up the pump blade. If you're able to get the coins out, then you can also replace the pump. The following link provides a source for a replacement part:
http://www.partselect.com/MultiModels.aspx?ModelNum=MAH2400&searchTerm=&RefineSearch=0
5) The post that includes the previous link also provides a schematic if you want to see what you're doing:
http://www.fixya.com/support/t942464-removed_coins_now_work_maytag_mah2400
Thanks benham!
Posted on May 11, 2009
    New Friend:
  • 10 Answers
Use Benham's advice, and also take apart the drain pump. There are three screws to do so. It's really easy.
Here are some photos to help you on your way:
The four screws on the bottom, I unscrewed them for this photo so they're easy to see.
The wire connector, there is a little clip that you push in like a clothesNasty Noise when Maytag MAH-24 pumps-out - elainekwok37_2.jpgthe pump.
The pump, attached to the hoses with springs. Press the prongs of the springs together and move away from the hose ends. Make sure you have a large pot or something to catch the water. I Nasty Noise when Maytag MAH-24 pumps-out - elainekwok37_3.jpgp pot. And be careful, that square thing can be HOT.
Hose one off.. success! Here's a better lNasty Noise when Maytag MAH-24 pumps-out - elainekwok37_4.jpg Basically you squeeze the end with two prongs and the end with one together, which loosens it.
The drain pump. I've already unscrewed the three screws. I did this over a cake pan to catch the water.
The opened pump. Not shown: evil bobby pin that was keeping the pump from spinning. Remove the obstruction, give it a good wipe then do all these steps in reverse.
Posted on Jul 29, 2011
    New Friend:
Elainekwok37's images helped a ton when combined with the posts above. You all saved me a day off from work and a bunch of cash!
Tip: Make sure to make note of the pump covers position with respect to the actual pump motor. It isn't keyed in any specific position so make sure when you reassemble you have the intake and output tubes in the right directions. If you make a mistake at this point you won't be able to remount it properly under the washing machine.
Posted on Nov 15, 2011
    New Friend:
I had asked for help with a nasty noise when my front loader [maytag] was draining and thanks to your help I removed the pump and found 3 quarters in side, it did not do any damage and the washer is A OK. Thanks so much.
Posted on Feb 01, 2010
    New Friend:
I wish to extend a HUGE thanks to Benham and elainekwok37! Our Maytag-MAH24 began making this terrible noise and the first posts I saw made me think it was bad bearings -- a very expensive fix. Fortunately, I searched again and saw these posts on fixya and, sure enough, a quarter was stuck in the pump. The whole fix took less than a half hour. As my wife said: Now we don't have to buy a new machine and we are 25 cents richer! Thanks again!!
Posted on Aug 19, 2013
    Problem Solver:
  • 5 Answers
6ya staff
SOURCE:
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
My Emerson Portable Ice Maker started makeing a loud grinding sound when pumping water -why?
I had this same problem that cropped up about 6 months after I purchased the ice maker. When it pumped water into the ice tray, the water pump would make a loud grinding noise. I inspected the pump and found that the impeller was in contact with the bottom of the pump housing. I partially disassembled the pump and inserted a small washer I fabricated out of electrical tape to enlarge the gap between the impeller and the bottom of the pump housing. I also took care not to over-tighten the screws when reassembling the pump. The grinding noise went away completely, and it's back to normal operation now. Even if you have no idea what you're doing, like me, it's a 15 minute fix with practically zero materials cost.
I have no idea what caused the problem originally, unless there was a washer that disintegrated over several months' worth of use.
Oct 29, 2012 | Emerson Im90 Portable Ice Maker
My lgis making a horrible noise and is now shoeing an e1 code dishwasher
The LG does suffer from "poor quality" motor that causes this type of noise. The main motor and pump assembly is common to give this type of problem. The pump seal leaks a small amount of water that gets onto the front bearing and causes a "grinding = humming" noise. This can be easly replaced once you have the bottom off and dishwasher on its door. The motoe has 1 screw in the back holding the motor to the bottom and two rubber seals for the water pump in/out into the washer. Just pull and move motor and pump assmbly and it comes free. Replace with a new motor and pump assembly...
Nov 18, 2011 | LG LDF6810ST Stainless Steel Built-in...
Loud noise on spin cycle
most common cause for this is pump bearing on water pump. remove belt and attempt to turn pump by hand. if it grinds get a new pump.
Oct 08, 2009 | Maytag PAV2300 Top Load Washer
Washer has started making a heck of racket during the drain/spin cycle. It's not consistant. Two loads may go thru ok no noise. A third load and it will make a very loud grinding chain like noise.
Grinding noises are most often the result of a failing water pump. The noise can increase during the spin\drain cycle due to the added load on the pump. Although less likely it could also be the drive belt rubbing on something or a pulley bearing failing. If you are able to locate and remove the drive belt, you should be able to turn the water pump pulley by hand. If the pump does not turn smoothly it is bad.
Aug 06, 2009 | Maytag Washing Machines
Admiral aav-1 makes loud grinding will not spin or drain
Hi, the drain pump impeller is damaged. you will need to replace the entire pump(drain) in this case.
You will hear this noise when the impeller become separated from the actual drive stud or, shaft.
Jul 13, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Kenmore elite heavy duty top load washer
REMOVE 3 SCREWS FROM BOOTOM PANEL CLEANE OUT PUMP RESOLVES YOUR PROBLEM , GRINDING NOISE SOMETHIG STUCK IN PUMP WONT DRAIN,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Whirlpool Duet Washer Making Loud Grinding Noise
not nesseccarrily your pump, possible you have a rear bearing going bad, which will sound as if a helicopter is coming through your laundry room. ( noisy pump can be the issue , honestly a better and cheapre problem to have) in order to determine if its apump problem you can remove the lower access panel and unplug the pump then start the spinn cycle, if it still loud the pumpms not hte issue.
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Loud noise -- water pump??
Yes you definately need a new pump assembly part number 21001906 $59.95. That is a maytag part number and it is a very common repair. The new pump is a revised design and will look different but will mount the same. Axcess through front panel.
Nov 25, 2007 | Maytag MAV7200 Top Load Washer
Maytag MAH2400A Front Load Washer Logo
3,128 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
