Question about Frigidaire FRS-26DR7D Side by Side Refrigerator
Ice crusher has stopped crushing
I can get ice cubes but my ice crusher has stopped working.
i can toggle from cubes to crush and vice versa and the lights work but i do not get any crused ice.
what can i do to fix it?
  • 5 more comments
  • sakkiy Jan 13, 2008
    I have the same problem. I am looking for a replacement part,
  • JustinR Mar 22, 2008
    Reverse problem: Crushed ice works when button selected but crushed ice also comes out when CUBE button is selected, both lights work as well.
    Justin
  • lesnil May 03, 2008
    Ice maker dispenses ice cubes but when I select crushed ice, ice cubes are still dispensed but not crushed. No repair effort has been made.
  • Anonymous May 07, 2008
    Ice maker stopped crushing ice.
  • pete shenkle Dec 07, 2008
    I have a amana sise by side refrig. my ice crusher tries to chrush ice but seems to get stuck. are the blades dull?
  • magnum1b Dec 29, 2008
    My ice crusher (GE Model GSS25JFMCCC)stopped working when a plastic part in the ice bin broke. I know how to change that, but I would also like to pull the control panel so as to clean the damper door on the dispenser and am at loss as to how to get that section apart. Any help would be appreciated.
  • Anonymous Mar 01, 2009
    GE side by side Profile TPS24PPBABS. Ice dispenser works in cube mode but not in crushed mode. The light comes on when I push the button but the auger doesn't turn. I checked the solenoid, it works fine and the bar from the ice dispense is correctly positioned within the acutator. In the crush mode the motor doesn't even hum, so it's not jammed or anything. Any suggestions?
    Guru:
  • 93 Answers
There is a little bar that is on the ice bucket. That bar has to go into the middle of the plastic square that is on the back wall of the freezer. Try Pulling out the ice bucket, get a hair dryer and run the hair dryer on the back wall of the freezer right above the hole where that little bar goes. After you run the hair dryer for about 10 minutes or so put your finger in the hole and pull down on the plastic square. Make sure when you put the ice bucket back in the freezer, the bar goes inside the square hole, not under it, not over it. In it. If that doesn't fix the problem you probably just need a new solenoid. Part number 5304404333
Let me know how you make out. Good Luck
Bill
Posted on May 16, 2008
  • 1 more comment
  • hafcanadian A
    hafcanadian A Sep 23, 2013
    I have the same problem, but have noticed that tweaking the spring on the back of the rod affects whether the gate opens or closes into the crush position. I can't quite figure out exactly what position the spring has to be in to consistently work. Is there a trick to it?
  • Elliott Hoang
    Elliott Hoang Sep 08, 2019
    Thanks Bill! That worked for me.
  • Paul Hansen
    Paul Hansen Sep 16, 2019
    Trying this defrost solution with samsung. Hope it works.
Perfect solution! Thanks Bill!
Posted on Jun 29, 2008
Thanks Bill!
Posted on Sep 08, 2019
I followed Bill´s instruccion and problem was solved.
Thanks bill
Posted on May 23, 2008
    New Friend:
My ice makers little plastic door broke so i got a new crusher assembly. Now the ice maker in the crush position crushed some ice but lets more full cubes through than crushed. any ideas?
Posted on Mar 15, 2013
6ya staff
SOURCE:
106.56679500 ice dispenser, crusher is not working
Are you getting cubes? There’s a solenoid that controls that. It switches it from cubes to crushed. If you’re getting neither, then the auger motor is probably bad
Oct 02, 2018 | Refrigerators
Why is my icemaker not chopping/Crushing Ice
If there are blades involved then they might be bent and/or need sharpening.
Jun 01, 2015 | Refrigerators
Ge gss fridge,ice dispenser problem.
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. The crush position is without the solenoid energized. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Your solenoid is part 45 and the linkage to the crusher is 46. The crusher is 41 on this diagram and parts list. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5150332&diagram_id=1239793#d1239793
Feb 28, 2010 | Frigidaire FRS3R5EMB Side by Side...
Ice crusher don't work
Hi, It sounds like the selonoid that shifts the auger is not working. This part is located behind the panel that the bucket pushes against. The little wire arm on the bucket goes into this. Sometimes they just get froze up from the moister. If you remove the panel/section the selonoid is in, you can see if the part has went bad.
I hope this helps you. Please let me know If I can assist you further.
Vic
May 23, 2009 | Maytag MSD2650H Side by Side Refrigerator
Ice maker only makes crushed ice, no cubes
The button which selects cubes versus crushed controls a solenoid which engages/disengages the crusher. If the mechanisms which crush and push the ice from the chute are all clean, free of ice, etc., then the solenoid is not working. It either has loose/dirty connections or the solelnoid is bad.
May 05, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Replace the switch behind the front panel on the freezer.
Mar 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice dispensor only dispensing crushed ice - not cubed
Make sure that your ice tray is properly instaled. There is a rod that must go into a hole. When you select ice cubes rather than crushed ice a solenoid raises which moves that rod. It then opens a flap so the cubes can bypass the crusher. Either your rod is not in the hole correctly or the solenoid has gone bad. The rod that I am speaking of runs along the underside of the ice tray. It has a spring on the rear end that holds the bypass flpa closed.
Dec 02, 2008 | GE GSH22JFT Side by Side Refrigerator
The crusher function on ice making part of my Maytag Zigzag fridge freezer is not working. I have ice cubes but no crushed ice
pull the bucket and check the solenoid on the back wall this is what shifts the bucket to crushed and cubed
Jul 31, 2008 | Maytag Refrigerators
Admiral Fridge Freezer
We had thought this was a free service...??? Yes, we fixed it ourselves, after trial and error. We pulled out the ice bin and there is an arm that is moves back and forth beside it. It had frozen up. That is the ice crusher. Thaw it out and it is fixed. By the way, the above posting was not by us--ours stated that our ice crusher did not crush ice anymore. Instead, cubes came out...
Jul 12, 2008 | Admiral 26 cu. ft. Side-By-Side...
Ice maker
There is something called a crusher control rod located on your icemaker bin. If you pull the bin out, you'll see it protruding from the backside of the bin. That rod inserts into the solenoid, which looks like a hole usually when looking in the freezer with the ice bin removed, it's toward the left side behind the bin.
This solenoid and rod work together to give you either crushed or cubed ice. See if the solenoid is stuck or iced up. You should be able to remove the ice and push it up and down to break it free.
Mar 26, 2008 | Maytag MSD2454G Side by Side Refrigerator
Frigidaire FRS-26DR7D Side by Side Refrigerator Logo
9,231 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
