If the ice maker is not getting water, it is probably the solenoid valves that let the water go through is burn out. Unplug the fridge and at the bottom at the back of the fridge there are valves that are controlled by solenoids. Unplug the connection to each solenoid and measure the resistance. It should read about 200-over 300 ohms. If you get a reading that is way high like mullions of ohms of thousands of ohms or infinity(open circuit) then the solenoid is bad. They usually sell the whole unit. You can't buy just one solenoid. They cost anywhere from 40- over a hundred bucks.
