Question about Tomtom GO 910 GPS Receiver
Does not hold it charge / will not turn on - Tomtom GO 910 GPS Receiver
  • Anonymous Nov 25, 2009
    how do I turn it on
    at the back near the terminals there is a black rubber grommet missing. Where can I get one.
    New Friend:
I have taken it to a local repair shop. Thanks Phil
Posted on Nov 26, 2009
Testimonial: "It was repaired the same day"
Htc evo 4g shift won't charge or turn on and I
Have you attempted taking the battery out and while the battery is out holding down the power button for a few seconds? If this doesn't work,
First test your charger to ensure proper charging. Clean charging ports. Remove battery and clean brass contacts with alcohol and q-tip
Jan 12, 2012 | Lands Phones
My Kodak will not turn on...it's been charging for a while now and when i turn it on all it does is turn on for about a second and then turn off..what could i do to fix it?
1/ Make sure your battery is still good (holds charge). If it does hold charge, 2/ then turn the camera on by pressing the play button. If it turns on, your camera's lens is faulty
Aug 17, 2010 | Kodak Easyshare M893 Digital Camera
Wont turn on charged it it still wont turn on ,
Try holding the power button while plugging it in. Also try holding the power button while wiggling a mini screwdriver in the reset hole
Oct 15, 2009 | Navigon 7100 GPS Navigator GPS Receiver
My iphone turned off all of sudden and won't come back on
welll hold the power and home button down at the same time and as soon as it turns off plug it in u should see a battery symbol that shows its chargeing
Aug 15, 2009 | Apple iPhone Smartphone
Bluetooth headset doesn't hold a charge very log
hold call button down till it blinks, than youll get intermitant light for about 30 seconds, than youll know its on. to turn it on hold call button down till it starts blinking at least 6 seconds. to turn it off hold call button down , itll blink for about 3 seconds than move your thumb off and when it ceases to blink its off. good luck
Jan 12, 2009 | Jabra BT350 Bluetooth Headset Headset
GPX MP3 Player MW3837 does not turn on
Not sure but I had same problem if you turn off the hold button on the left hand side and hold down the play button it should turn on.
Jan 11, 2009 | GPX MW3837 MP3 Player
When I turn the mp3 player on it says hold then bye and turns off
there is a hold switch on the left turn it off and charged it.
Jan 01, 2009 | GPX MW-3847 MP3 Player
Phone wont hold a charg and wont turn on
what you have to do is to clean your phone using isoprophyl alcohol i mean you clean the main mother board then you dry it using hair dryer ,after all that try to replace the battery it has reach it death neal the cells inside they are no longer able to hold the charge.advice by dogy.
Jan 04, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Phone won't turn on
You may need a new battery. Also, hold the power button in for at least 10 seconds before letting go. The RAZR has a bad habit of not completely turning on unless you hold it in long enough.
Nov 30, 2007 | Motorola Mobility RAZR V3
Tomtom GO 910 GPS Receiver Logo
343 people viewed this question
Top Tomtom GPS Experts
LP
Marvin
Marvin
Ekse
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
