Sakar 62350N wireless multimedia keyboard suddenly stopped working. I have replaced the batteries, unplugged and re-plugged the USB receiver, rebooted the PC, and re-insatlled the drivers. But the keyboard is still not working.
K i had the exact same issue. read all these posts online and no one could help me. so i took matters into my own hands. after removing all the screws from the back of the keyboard (figuring i had nothing to lose) i came across a very simple setup. and if you follow the two power cords that run from the batteries you will see they are connected to a card. two thin pieces of plastic are supposed to overlap each other and using the pressur from the back of the keyboard being screwed to the front of the keyboard connect to the power card. weeeeellllll i figured it must not have enough pressure agains the plastic pieces and put a lil piece of a business card i ripped up on top of them to make the connection tighter. WHHHHHHHALAAAAA ! freakin works! bahahahaha
This fix was awesome. I was pulling my hair out, but then I read your post and 5 minutes later problem solved. Thanks
Thank you, timbuckley21. I have the 62350NS and had the exact same problem. I followed your instructions, and now I'm typing on a DIY repaired keyboard. Very simple fix and worked great. Thank you. I recommended your post on FB.
The only thing I did differently was to use a section of a wide rubber band that I cut to match the length of the little rubber piece on the bottom/back of the keyboard which pushes the contacts together. I then taped this on top of the factory rubber piece. This provides a nice firm connection.
Thanks again.
Travis
Either your system is not compatable or your usb module is not working. If you have anything other than a mac or windows machine then the chances of it being compatable with the os if chancy.
Awsome!!! Fixed my problem as well!! Thank you for this quick easy solution!!!
