You can try this solution, but it may not work. As of this time there is no support for your scanner with Vista from the manufactuar.
1) download the xp version driver by going to this link and choosing the Full Version.
http://artectv.com/Service_e/nl/home/Old_drivers.htm2) right click the exe icon.
select properties , then compatibility and choose xp service pack 2.
Right click again and RUN as administrator
allow this program to run even though it has not been aproved by microsoft.
3) go to c:/windows/twain_32/ePlusPro/Scan32.exe
right click SCAN32.exe
select properties, then compatibility and choose XP service pack .
Right click again and RUN as administrator.
I actually created a shortcut to the desktop of scan32.exe.
Now everytime i click on this..........my artec e+pro scanner work absolutely fine.
The only problem is none of the shortcut butons work on the front of the scanner , but you can choose where to save the image to through the Twain program, then edit it it whatever program you require.
