Maytag Atlantis MDG7400AW Gas Dryer Logo
Posted on Nov 26, 2009
I have a gas dryer that does not stay hot. The heat goes off too soon. Is that the high limit thermostat?
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Nov 26, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
805
Points
5
Hi, I have the Maytag Neptunes which were a couple of years old but never used. Turned out that they both (I had 2 of them) had faults with the motors and needed new motors. Because I had 2 they were both doing the same thing which was cutting out before the clothes were dry because there was something wrong with the motors. I am in NZ and my machines would have had to have a currency conversion but I don't think that was the root of the problem. It took me quite a while ringing service people here at the supplier to find out that there had been an issue. It didn't cost me to have them fixed as it was a fault with the machine. If I had only had one machine I am not sure if I could have proved this.
  • Randy James
    Randy James Sep 19, 2013
    I have a like problem, found a good troubleshoooting video on U tube they tell you to check the thermostates and if they do not read a resisitance of 500 to 50 ohms or they read infinity they are bad. if you go to U tube and type in Maytag dryer not heating. you should get the video.
Gas dryer works fine for 5 min., then flame goes out, display time goes to 1 min. (cool down mode). I've tested high limit thermostat. It is OK. I put on new gas coils. Error codes 3 and 10 appear on
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
GOD IS GOOD !!!! AND THAT IS WHY MY ADVICE IS FREE
Aug 17, 2014 • Dryers
Dryer cuts off soon
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Thermal Fuse
Air Flow and Heat
Warning
Will not get hot
If it's a gas dryer, check the thermal fuse, gas valve solenoid, igniter, element, flame sensor, high limit thermostat, or cycling thermostat.
If electric - check the heating element, thermal fuse, or thermostat.
Overall, dryers, specifically electric dryers, are very easy to work on - youtube has some great videos too.
Lg dle8377wm over heating
You will need to replace the "high limit thermostat". Under normal conditions, the dryer's primary operating thermostat will cycle the heater on and off to prevent temperatures from rising too high within the dryer. The hi-limit thermostat will remain unaffected through all of these cycles, since the temperature inside of the dryer will stay lower than what is required to activate the hi-limit sensors (generally 250-degrees Fahrenheit, though the exact temperature may vary on some dryer models).
Here is the part you need to order.
Nov 09, 2012 • Dryers
Ge dryer way too hot. I have cleaned all the lint out but still way too hot. unplugged vent hose and ran machine still too hot. Took apart machine and tested continuity of heating element and its fine....
I do not know your definition of "way too hot". Remove the exhaust vent and insert a accurate thermometer in the dryer exhaust. Run the dryer on high heat. The temperature should get up to 165 degrees then cool down to about 125 degrees then back up to 165.
If it goes above 165 and stays there replace the high limit thermostat.
If it cycles correctly it is OK.
I have an older Kenmore gas dryer model # 97260100 it heats up for 15 minutes then goes cold, drum continues to run can u give me any insight as to what needs to be replaced
The problem is either of the cycling thermostat, high-limit thermostat or the gas valve solenoid coils sitting on top of the gas valve assembly. Disconnect power then verify any of these condition by bypassing the thermostats. Refer to the image below and locate the thermostats.
Note: This is an image of an electric dryer but the thermostat and the thermal cut-off (cut-out) locations are the same.
Disconnect each of the thermostat wires then connect and insulate them properly. Once done, reconnect power and start the dryer. The gas valve solenoid coils are indeed faulty and both need to be replaced if the problem still persists. Click here for the procedure in replacing the solenoid coils.
Gas Valve Solenoid Coils Replacement Procedure
Either or both of the cycling thermostat and the high-limit thermostat are malfunctioning if the dryer continues to heat up with the thermostats bypassed. Disconnect power then reconnect the cycling thermostat wires but keeping the high-limit thermostat bypassed. Reconnect power then start the dryer. The high-limit thermostat is the culprit if the dryer continues to heat up. If not, then the cycling thermostat is the culprit.
Also do the other way; that is reconnecting the high-limit thermostat wires but keeping the cycling thermostat bypassed. The cycling thermostat is the culprit if the dryer continues to heat up. If not, then the high-limit thermostat is the culprit.
Replace the faulty thermostat and it should solve the problem.
Have a kenmore model # 110.72822101, where's the thermostat located, my dryer gets hot then cold
The cycling thermostat or the high-limit thermostat may not be the problem but rather the gas valve solenoid coils sitting on top of the gas valve assembly. Disconnect power then verify this condition by bypassing the thermostats. Refer to the image below and locate the thermostats.
Maytag dryer ldg7500 - gas continually turns on & off, no heat
Could be a number of things....
The ignitor is bad and it will not keep pulling enough current to hold the gas vavle on.
The dryer cycling thermostat is bad and is cycling it too often...ie, shutting the gas valve down too soon before it can run long enough and then turning it right back on.
The vent is blocked or plugged and the air gets too hot to fast.
The high limit switch has gone bad doing the same thing as if the cycling stat goes bad.
Fan/blower is bad and bot moving enough air...same symptoms as blocked vent...
Need to start eliminating the possiblities one by one...
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Heatman101
Jan 20, 2010 • Dryers
2answers
Element is staying off too long
element should cycle a little longer than that i think 2 min then cycles high limit thermostat u checked could be reading wrong when its gets to certain temp that thermostat opens up so wont get so hot and catch on fire .. take thermostat is the smallest one is your high limit thermostat probably the one going bad
Jul 12, 2009 • Dryers
Crosley Dryer Heats then stops
If im thinking right, this dryer has the element in the top left corner.  This unit has two thermostats, one mounted right above the element, and the other in the lower left front mounted on the fan housing.  The one in the front is called the high limit thermostat, which means when it gets to a preset high temp, it cuts off the system until cooling occurs.  The top thermostat, mounted above the element is the operating thermostat.  It probably is one of the two thermostats.  Its a very good idea to replace not only both of the thermostats, but the fuse as well.  The fuse kit (Maytag Part# LA-1053) comes with a thermostat and 2 fuses, be sure to follow he instructions on how to determine the fuse for electric and gas.  The high limit thermostat (Maytag Part# 53-0771) is an easy replacement.  Something is causing the unit to short cycle.  Sometimes you can hot-wire the operating thermostat (use caution, severe caution if doing this, not recommended if you arent sure whats going on).  By doing this (removing the two wires from the thermostat, taping them together), you can watch and see if the element stays on longer, at least until the high limit switch comes on.  This is really not recommended, if the high limit is out, it will not be good.  Just easier to replace them both.
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
