My n and the lens is stuck out it won't go bacck in i have changed the batteries. when i press the power button the green light comes on for brief moment make make a sound and shut off.
My S730 has done all the same things to me. New batteries in, 2 minutes later the power bar indicated they are flat. Amazon were very good & sent a replacement real quick. My replacement is doing the same thing now.
Try to power reset your camera by removing the batteries for a minute and reattach them again.
Use lithium batteries.
If that doesnt work, consider sending your camera for service.
I'm having the exact same problem. My camera is stuck on zoom, when I try to turn it on it stays on a few seconds.. beeps 3 times and then shuts off. I have brand new rechargable batteries and one's that I bought a few days ago and used, none of them work. My camera took good pix the last 2 days but now it's acting crazy!! HELP!!!!!!!!
the camera is off with the lens out. I've changed the batteries. When I press the power button the green light momentarily comes on. The camera remains off.
it says send your camera in for service if the problem continues...where should I send it?
I recently started having the same problem. The camera emits a strange beep and will shut off. Nothing helps. Customer service wants a ton of your personal information and won't refer you to tech support unless you supply said info.
Servicing this camera will cost more than just buying a new one! I may well as well by a brand new one - just different brand.
my lens on the camera is stuck. I changed my batteries and i press the power button but it still won't turn on. Then the screen goes blank and it turns off.
