Milwaukee Tool Milwaukee 48 11 2830 Battery 28V Logo
Posted on Nov 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why my 28v doesn't fully charge. when charging indicator light is red. there is 4 charge indicator. when it reach 2 green light comes on showing fully charged. you would use it for about 20 minutes and it goes dead. i try charging several times but nothing change. can you help me with this battery? thanks!!!!!!!!!!!!!!!!!!!!!!!!
Fred Yearian
Level 3:
  • Master 5,603 Answers
  • Posted on Nov 26, 2009
Fred Yearian
Master
Level 3:
Answers
5603
Questions
Helped
2249076
Points
16162
One or more cells of the battery have gone bad. The technique of measuring the state of charge of the battery is VERY limited.
I would recommend letting the battery cool after charging... THEN in a day, charge it again without using it. Do this for several days and see if the battery improves. If not, time for new battery.
DO NOT discharge these batteries beyond the point where the tool starts to slow down. You will reverse charge the weakest cell from the ones still deliveing power and the reverse charge will permanently damage the weakest cell.
18v 12 cordless trimmer/edger. Why won't it start?
the trimmers switch may be faulty.
CHARGING THE BATTERY PACK
Battery packs for this tool are shipped in a low charge condition
to prevent possible problems. Therefore, you should
charge them until the green LED on the front of the charger
comes on.
NOTE: Batteries will not reach full charge the first time they
are charged. Allow several cycles (operation followed by
recharging) for them to become fully charged.
CHARGING A COOL BATTERY PACK
See Figure 3.
If battery pack is within normal temperature range, the red
LED on charger will come on.
NOTE: If the charger does not charge the battery pack
under normal circumstances, return both the battery pack and
charger to your nearest Ryobi Authorized Service Center for
electrical check.
n Charge the battery pack only with the charger provided.
n Make sure the power supply is normal household
voltage, 120 volts, 60 Hz, AC only.
n Connect the charger to the power supply.
n Place the battery pack in the charger aligning raised rib
on the battery pack with the groove in the charger.
n Press down on the battery pack to be sure contacts on
the battery pack engage properly with contacts in the
charger.
n Normally the red LED on charger will come on. This
indicates the charger is in fast charging mode.
n Red LED should remain on for approximately 1 hour
then the green LED will come on. Green LED on
indicates battery pack is fully charged and charger is
in maintenance charge mode.
NOTE: The green LED will remain on until the
battery pack is removed from the charger or charger is
disconnected from the power supply.
n If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
n The battery pack will become slightly warm to the
touch while charging. This is normal and does not
indicate a problem.
n Do not place the charger and battery pack in an area of
extreme heat or cold. They will work best at normal room
temperature.
NOTE: The charger and battery pack should be placed
in a location where the temperature is more than 50°F
but less than 100°F.
n When batteries become fully charged, unplug the
charger from power supply and remove the battery
pack.
Source(s):http://toolboyworld.com/eBay/Ryobi_P110/...
My nokia bh503 headset not charging
Leave it plugged in for 4 hours. Yello should turn red then green when fully charged
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
I have 4 Milwaukee 28v tools and 4 batteries. Lately when using the sawzall or circular saw, with any of my fully charged batteries the tools stall after only a minute or two of use and the battery...
Your batteries are at the end of their rope and need to be replaced. All batteries die, some sooner, some later. And if you do not maintain them in a manner consistent with directions they will fail sooner!
Usually the red light is on to indacate the batteries are being charged,now the green is the only light that is on
The green light on the charger usually indicates that the batteries are fully charged and you are ready to go. Does the controller show the batteries are fully charged? Can you operate the power wheel chair for several hours? If so, you are good to go.
When you connect the charger, if the light goes to red to green within a few minutes and the battery power does not last more than 1-2 hours or less, it may indicate that that the batteries will not take a charge anymore and need to be replaced.
On a vector jump start system, does the green light have to stay on to indicate that is charged> what if only the 2-3 red light go on when i press the test button?, when the green is flashing while...
2 - 3 red lights indicate not fully charged. Green light = fully charged.
Not fully charged does not mean it will not function. For best results, your device should be fully charged. If you have an emergency and are not fully charged, it will not hurt to try to help with a partial charged device IMHO
Thanks for posting at FixYa.com
8helpful
Microtek Inverter not fully charging the batteries
xenion pure shinewave inverter not charging fully
Rechargable Batteries Battery Charger
When batteries are placed into the charge mode, the red light will come on.
When fully charged, on those units with a green light, the green light will be an indication that your batteries are charged and if your unit has no green light, the fully charged indication will be when the red light turns iff.
2helpful
3answers
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Top Milwaukee Tool Drills Experts
ADMIN Andrew
ADMIN Andrew
john h
Steve Pack
Steve Pack
Are you a Milwaukee Tool Drill Expert? Answer questions, earn points and help others
