Mackie 1604 Vlz3 16 Channel Mixer Logo
Posted on Nov 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi seems to be no dry signal getting into mixer sends still workin?am workin on a mix and gutted regards my mixer is a 1642vlz pro cheers
Michial Gueffroy
Level 3:
President:
  • Master 1,140 Answers
  • Posted on Nov 26, 2009
Michial Gueffroy
Master
Level 3:
President:
Answers
1140
Questions
0
Helped
532209
Points
2214
Here is where you can get the service manual:http://www.free-service-manuals.com/Mackie_1642-VLZ_Pro_Service_Manual_L15833/ Let me know if this helps.
How do i hook up monitors to mackie1604 vlz pro to where you can hear music and mike.
Plug either a powered monitor or amp and then speaker into one of the aux sends. Now adjust the monitor mix using the appropriate aux send pot on each of the channel strips you want to send to the monitor. Think of the aux send pots as faders for the monitor mix the same as the main fader for the ain mix.
tip
How to Set up Auxiliaries on a Mixer.
Here are some tips to set up the auxiliaries properly on your mixer:
  • Step1:
Your auxiliaries allow you to send the signal from a channel strip to somewhere else while maintaining the signal on the channel strip. For instance, you can use auxiliaries for monitor mixes for performers in a live environment. You can also use auxiliaries for external effects processors or a number of different situations.
  • Step2:
Set the auxiliaries to pre-fader to allow you to change the level for the auxiliary with the auxiliary knob but not with the channel fader. Most mixers have a "Pre" button that allows you to enable pre-fader mode. If you don't have the button pressed, your auxiliaries are in post-fader mode, which means your channel fader will affect the signal level of the auxiliary output. For monitor mixes, you usually want to use pre-fader so you can control monitor mixes independently from the front of house mix. Some effects processors will be better to run post-fader, though, so don't always rely on pre-fader.
  • Step3:
Send out your auxiliary sends. On the back of your board, you there are the auxiliary outputs. For a monitor mix, you will use these outputs to connect to the inputs of the monitors. When using an effects processor, you will use the auxiliary output to connect to the input of the effects processor.
  • Step4:
Plug in a return if necessary. If you are just doing monitors, you do not need returns to the mixer. When using effects processors though, you need a way to get your effected signal back to your mixer. Take the output of the effects processor and connect that to the return input on the back of the mixer. Now you will have to adjust the return section on your channel strip to get the desired signal.
  • Step5:
Use the auxiliary knob to set the desired level. Once you know if you are running pre- or post-fader, and you have your inputs and outputs all correct, you can start sending signal to your auxiliary output. Turn up the auxiliary knob until either your monitors are set correctly or until you have the desired amount of signal going to your effects processor or other outboard equipment.
I'm trying to plug an active speaker into aux 3 for a third monitor mix but it doesn't work (I do the same with aux 1 and 2). Am I missing something? Cheers,
I answered another post of this earlier. The AUX3 is strictly POST FADER... you MUST turn the channel sliding fader up to send signal to AUX 3. Also the AUX3 channel gain KNOB must be turned up. Also the AUX master gain KNOB must be turned up. Make sure your cablles are balanced TRS cables from the mixer to the powered speakers.
1helpful
I have a behringer eurorack ub1204fx hooked up to a bose L1. I can't seem to get the reverb to work
you have to set three gain controls to pass the FX into the mix. The FX send gain for each input channel, the FX fader which sends the FX mix to the effects unit, and finaly the gain that sends the FX output to the mix. Depending on which effect you choose, some are very subtle.
When I plug the guitar into an mixing board/amp no sound comes out. From the mixing board, I can see that the mixer is receiving a signal but still nothing comes through the speakers. I own a Fender...
If the mixer is receiving signal, then the problem is pilot error at the mixer, not the guitar. You did not mention what type of mixer you have so I have no way of helping. Common problems would be failure to send the guitar channel to the mixing buss, leaving the channel muted... but we really need the mixer and model number to give more help that that.
1helpful
Where on a 16:2 allen heath wizard would you hook up a 482i sonic maximizer?
The answer all depends on what you want to achieve.
  • If you just want to enhance the sound of 1 or 2 instruments / voices you could take a signal out from an individual channel on your mixer using the direct out and insert jack sockets on that channel however this may make it difficult to control in conjunction with teh E.Q. controls on that channel as the Sonic Enhancer would be pre-fade and pre E.Q.
  • Alternatively you could send several mixer channels of your choice through the Sonic by using one of the sub-mix outputs to give a feed to the Sonic, returning it to the main mix either via a couple of spare channels, or the paired stereo inputs that are only routed to the main outputs.
  • Thirdly you could use one of the auxiliary sends to allocate different levels of signal from any number of channels to the Sonic. These are normally used to supply a separate mix to on-stage fold-back systems, monitors etc. Here I would use one of the 2 post fade ones rather than the pre-fade - to avoid negating what you have set on the main mixer e-q (tone controls)/. One advantage of this option is that it allows you to only enhance part of the signal from a particular channel and to allow part to bypass the Sonic without enhancement. I think that this would be my preferred option unless all the auxiliary feeds are needed for other purposes.
  • Lastly you could just put the Sonic on the main outputs of the mixer. This would mean that the same level of enhancement would be applied to the whole mix. As the Sonic Enhancer only has unbalanced (mono) jack sockets this later option does reduce the likelihood of you introducing unwanted radio interference to the system, compared to putting it at an earlier stage in the mix because, as the Sonic is unbalanced, everything else after it in the mix chain will also be unbalanced.
How do you control volume for a specific instrement in a sub group being used as a moniter mix with out afecting the main mix
Send the signal to the subgroup via and Aux channel PREFADER. This will allow you discrete volume control over your monitor mix.
Hi i have djx 750 and i have connect the master output on my amplifire and the tape or both to my line in from my pc sound card!!! the problem is that when i have open the mic from my mixer i can here it...
i have djx750 mixer, and i want to connect speakers to it,but the cable for the speakers are guitar jack leads and back of mixer are scart can i get a cable with guitar jack and scart on same lead??cheers
Using the USB connection to send the stereo mix to a computer
You have to insert a track into Reaper "arm" it. If you can't figure it out, I'd suggest posting in the Peavey forums.
Top Mackie Music Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Mackie Music Expert? Answer questions, earn points and help others
