Kodak EasyShare M853 Digital Camera Logo
Posted on Nov 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lens 122 error lens wont retract not usable found out common problem with this model
Pania Lee
Level 3:
Genius:
  • Kodak Master 1,099 Answers
  • Posted on Nov 27, 2009
Pania Lee
Kodak Master
Level 3:
Genius:
Answers
1099
Questions
Helped
218831
Points
1986
My Camera lens trys to open but wont.
Lens stuck, is common defective that need new lens unit replacement or just repairable.
Causes of a Lens Error: There are a number of ways with which a lens error can be caused. Particulates might have managed to get into the mechanical bits that allow the lens to retract, a purely physical interference with the lens mechanism. If the camera was dropped, especially while the lens was extended, there's a pretty good chance something might have been knocked loose, such as the guide pins upon which the lens withdraws and retracts.
How to Repair a Lens Error: As scary as a lens error might seem, there are some easy fixes. Before trying any of them out, however, first take a good long look at your camera warranty and maybe have a chat with the company. If the lens error will be covered under the terms of the warranty, go for it. Even some of the simple fixes mentioned below might void the camera warranty. Frankly, however, it's unlikely that a lens error will qualify for the warranty.
Additional details could find in this article link: fixing-lens-error-on-digital-camera.html
Keep us updated.
Lens error, cannot focus, lens not retracting
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try:
1helpful
2answers
I had the E18 error--lens wouldn't retract and
Focus problems are quite common after a lens error, it sounds like you still have an issue with that lens unit. If you need help, there's a great site taht just specializes in the powershot problems, nothing else at all. Try going to www.camerasandparts.com and you'll see the fix for this for your SD890 camera. I hope that helps, that site is amazing for the powershots and that's where a lot of people go for help with these. Good luck with it.
1helpful
Lens Error - won't retract
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Canon A560 dropped.when the cam is on lens wont retract anymore
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
2answers
Kodak EasyShare M853 Digital Camera lens error 122,1,0,0
You will be offered a repair or a service upgrade.
To check on your options, go to www.kodak.com/go/itg.
PowerShot SD630 lens stuck out, says lens error, restart camera
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
1helpful
Lens error and will not retract
2answers
Try helping the camera to retract using your fingers while you turn camera off, try also helping lens to full extent if they don't.if you do not succeed in this simple way the camera lens must be taken apart and reassembled at a repair shop.
8answers
Lens error 122
ok,white screen is LCDproblum or flex conecting pro,error 122 is ur lens barrel stuckup or mechanical gears problum this is repareable u try ur local repairer
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
