When i turn on my tv i get pink dots all over the screne. when i turn it off and back on again the pixels go away.
I had a problem with the TV going on and off several times before "warming up" and then having pink dots. I would have to reboot to get rid of the dots. I called 1-800-SAMSUNG and reported that I had problems with the capacitors. That is what was causing the problems - cheap capacitors and Samsung is aware that this has caused many TV's to malfunction. My set was not under warranty but Samsung sent a technician across two state lines to fix my TV. As long as the problem is the capacitors Samsung will cover this service call 100%. My TV is fine now. BTW - capacitors which are sold in Radio Shack are not expensive. Why Samsung chose to put the cheapest Korean capacitors in their expensive TVs is a mystery.
So if your TV need warming up and has pink dots on the screen - call 1-800 -SAMSUNG and tell them your capacitors are malfunctioning.
