NO. It is meant to be used. You are not doing anything that it is not meant to do. But, remember that if you use the BT connection then the phone may get hot and use up more battery. In the long run it may be harmful as the battery will wearout that much faster and the heat has always caused damage everywhere. So use the cable connection as long as you can. Bt is fine but the phone had to work double, by working the BT to work the GPRS. In case of cable it just has to concentrate on the GPRS.
U should use data cable to connect to internet as it will consumes less battery along with full signals and speed
Ebuddy does not work on my nokia 5130 xpress music
My internet is not working my mobile 5130 give me error [link not available try again]
