Question about Kyocera Mita KM-3035 All-In-One Laser Printer
Sytem error C6050
Nothing works on machine, has system error C6050
  • 1 more comment
  • MPeterson Jan 14, 2008
    This is on a Kyocera Mita KM-3035 KX
  • Anonymous Nov 05, 2008
    system error
  • Anonymous Mar 20, 2014
    reset producer
  • 36 Answers
This Code means low fixing unit temperature. If the power goes off and on, or Suzy Sec. has a space heater on the same circuit, this could be a false code.
Enter the service mode by keying in the numbers "10871087", on the key pad. enter the number 906, press start, press "execute"on the touch panel. The machine will reboot.
If the code comes back, you either have a bad thermistor, thermostat, or heater lamp. I have only had to replace the thermistor. The Fuser comes in the maint. kit ,so I always have some old ones laying around.
Posted on Jan 18, 2008
  • zyanya_888 Jun 10, 2011
    fantastico lo pude resolver sin mayor problema mi dia empezaba un poco mal pero con esto me devolvieron la alegria gracias
Fusing errors aren't reset with 906, you'll need to run sim 163
Posted on Feb 27, 2008
I tried this, and mine is not rebooting. Any Ideas?
Posted on Aug 07, 2008
  • Anonymous Aug 07, 2008
    how do you run sim 163?
Who the f*** is Suzy Sec.???
Posted on Sep 30, 2008
6ya staff
SOURCE:
What do I do with the error code of C6050 on a Kyocera KM-3035 machine
You need to go into simulation mode and enter U163.
This simulation number needs to be reset.
Nov 09, 2017 | Kyocera Office Equipment & Supplies
Kyocera C6050 error
C6050 Error
Abnormally low fusing unit thermistor temperature
SIM 163 Reset (only do this one SIM, by doing others you could cause your machine to no longer function. Also see note at bottom.
Entering Simulation Mode
1. Press the system menu/counter key.
2. Select Service setting using the up/down cursor keys.
3. While pressing the start key and the # key, press the enter key. (Maintenance mode is entered.)
4. Select Maintenance mode using the up/down cursor keys.
5. Press the enter key.Enter the maintenance item (163 Resetting fuser problem) number using the up/down keys.
6. Go to step 1 under method below.
Resetting the fusing problem data Description
Resets the detection of a service call code indicating a problem in the fusing section.
When a service call concerning the fusing section occurs, turn the power switch off and open the front cover.
Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
Purpose
To prevent accidents due to an abnormally high fusing temperature.
Method
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020,C6050, and C6400 are reset.)
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
Note:Sometimes in order to do the reset when the machine is in an error state you need to open the top cover (like to replace the toner) and leave it open until you have performed the reset
Jul 03, 2014 | Kyocera Office Equipment & Supplies
MY COPIER (KYOCERA 1635) DISPLAS ERROR C6050. HOW
C6050 Abnormally low fuser unit thermistor temperature The fuser temperature remains below 90°C/194°F for 1 s. Poor contact in the thermistor connector terminals. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Broken fuser thermistor wire. Measure the resistance. If it is ∞ ω, replace the fuser thermistor. Fuser thermistor installed incorrectly. Check and reinstall if necessary. Fuser thermostat triggered. Check for continuity. If none, replace the fuser thermostat. Fuser heater M or S installed incorrectly. Check and reinstall if necessary. Broken fuser heater M or S wire. Check for continuity. If none, replace the fuser heater M or S. Code Contents Remarks Causes Check procedures/corrective measures
Apr 09, 2010 | Copystar CS-1620 Copier
Error Code C6050
First you must get into the service mode by keying in 10871087
The screen will start blinking - then key 163 and the screen should read cancel or execute -select execute
when it is complete turn unit off then back on and see if that worked, if not buy a new fuser unit. They cost around $150,00 to $200.00 depending on who you buy it from.
May 25, 2009 | Kyocera Mita KM-2050 Printer
Error: Call Service Code: C6050
try to press code 10871087 then 163 and lastly press clear/stop button for a while.
Nov 17, 2008 | Copystar CS-1620 Copier
Cannon l120 laser fax shows sytem error E100 and alows nothing to be done to it.It has worked for a few months now. Help!!!!!!!!
According to the knowledgebase on Canon USAs web site, System Error Exxx may be corrected by removing all power (unplug) for ten seconds, then plugging it back in.
Jun 30, 2008 | Canon Office Equipment & Supplies
Kyocera KM4035 Service Message C6050
the above is incorrect, Kyocera made a mistake by having a thermistor that physically touches the upper heat roller/belt.. it has worn the roller to a point where it throws up the error.. you will have to install a new fixing unit.
I have done over 25 warranty replacements regarding the 4050/5050/2525 etc.
Sep 14, 2007 | Office Equipment & Supplies
Kyocera Mita KM-3035 All-In-One Laser Printer Logo
8,463 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
