My maytag atlantis mav6200 only spins on whites cycle
My matag atlantis mav 6200 will only completely wash in the whites cycle. If I run the machine in any other cycle it spins out, but will not drain and leaves the tub full of water.
the machine only works correctly on the whites cycle..I've tried several times, but it will only empty the tub on the whites cycle.the machine only works correctly on the whites cycle..I've tried several times, but it will only empty the tub on the whites cycle.
AnonymousMar 24, 2014
The washer pumps in water but stalls in the wash cycle. When you switch to Spinit will spin and drain the water in the tub.The washer pumps in water but stalls in the wash cycle. When you switch to Spinit will spin and drain the water in the tub.
You can't post conmments that contain an email address.
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
hi thanks for the question with any washer if you use a hi sud zing detergent it really slows down the spin cycle check this just fill & drain 2or 3 times use some veniger try this thanks the appliance doc
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
