We have an Admiral 21.7 cu ft ASD2120DR side by side refrigerator and smelled burning this morning after a sizzling sound. It still seems to be working but now we hear clicking coming from the compressor. I turned off the automatic ice maker thinking that was the problem but still hear the clicking sound coming from the compressor. THANKS FOR YOU HELP.
SOURCE: Admiral Refrigerator makes hollow ice
Hollow ice cubes are due to low water pressure to the fridge. Water thru the door should have good pressure behind it. This is a good indicator of water pressure. Should be able to fill a glass quickly. Causes for low pressure are self-piercing saddle valves on the water line (switch to drill type (1/4") valve) or reverse osmosis system or filtering system on water line to the fridge. R.O. systems should not be used. Increase water pressure and that will fix the hollow cubes. The loud noise may be the sound of the water valve on the fridge when it is acivated. This sound is normal and some are louder than others.
SOURCE: problem with fridge ice maker
assuming the freezer is cold enough and that you have a valid water supply hooked up, either the icemaker is bad or the water valve is bad, best idea is to replace both.
SOURCE: Frost build up in freezer/ very little cold air is blowing down to the bottom
HI thanks for your question. look to see if you can hear the fan motor running. if it is check for frost build up. if frost build up. its not going into the defrost cycle. thanks the appliance doc. please rate my answer. thanks.
SOURCE: ice maker on Admiral HMG 62165 side by side
check the lever in the ice bin. if it is stuck in the up position it thinks the ice bin is full and will not make ice. Just wiggle it to the down position.
