Freezer in my refrigerator is not freezing some things like ice cream and ice pops solid
Get a freezer dial thermometer (about $5-10 at grocery or box store) and check the temperature, then adjust the freezer (NOT refrigerator) setting dial (usually just inside the top of the cold cut section) a number at a time colder and see how that changes the temperature.
Vegetables and ice cubes freeze hard at about 28-30 degrees F, so freezers are usually set at about 5-10 degrees F, and not above 15 for safety. However, ice cream that is high in cream content generally will be runny to about 25, and soft down to about 0-10, so you may need to set your freezer as low as zero degrees F.
The comment on cleaning the coils is very important - you should do that about yearly, or more often if you have shedding pets. Be gentle with them - you do not want to bend them, as they carry refrigerant fluid, and repairs are expensive. The coils can be under or on the back of the unit, and it is best to not only vacuum them out, but also to blow them out if possible before vacuuming - with compressed air hose if you have it, else with a cleaned-out shop vac on blow setting. Be sure after you blow it out that the fan (usually accessible from the back by removing a cardboard cover after disconnecting power) is not blocked by a clump of lint - it should spin freely. The compressor (roundish tank with wires and tubing coming out of it) should also be blown / brushed off, as lint accumulation makes it run hotter, which reduces freezing capacity.
Also - try putting your ice cream as low in the freezer unit as possible (cold air sinks), and as far back as possible so it does not warm up as much when you open the door. Side-by-sides are bad for this, because all the cold air pours out every time you open the door. You might also try packing something around the ice cream to reduce the effect of opening the door - like bags of frozen vegetables, for instance, or even a wrapped layer of cardboard (although that will also make it take longer to initially freeze).
Thanks for trying. I had already tried cutting off the power. I let it sit for 20 minutes the first time and 2 hours the second. I even have the freezer in the off position but it is blowing constantly.
