After you connect the antenna cable to the TV go into the setup mode and on the tuner line change it from cable to air. Then do an automatic channel search and you're done.
there are no analog over the air channels, only digital ones, there should be an input button, maybe even an antenna select button on your remote, or in the set-up menu using the buttons on the front of the tv. there may also be a seperate connection in the back of your tv for cable, or over the air antenna
In order to set up HD you need either an HD antenna, or a digital cable/satellite box. If you have cable or satellite you have to make sure you have HD service through your provider. If you do just hook up your box to your T.V. using either HDMI or component (blue, green, red). Then you'll have to look through your channels to find out where your HD channels are.
