Question about Westinghouse SK-32H240S Television
Power light comes on but no image - Westinghouse SK-32H240S Television
    New Friend:
Panasonic 42 inch plasma flashes power on 7 times but no tv
Posted on Nov 28, 2009
6ya staff
SOURCE:
What component board on the Toshiba regza 42rv530u needs to be replaced? Where can I purchase this component online?
My advice is take it to a television repairer. It is far cheaper in the long run. Fixya is full of people who have bought every board off eBay and still don't have a television that works. Correct diagnosis is the key plus experience of that particular make or model. The course to be a television engineer is 2 years full time college course.
Jan 24, 2018 | Toshiba Televison & Video
There is no image or light coming from my projector
Hi Sane,
Multimedia Projectors uses a high power lamp to project the image onto a screen. These lamps have a typical life of 2000-3000 hours. It is quite possible that it may have blown.
  1. Confirm that the unit itself switches on. You should have some sort of visual feedback from the projector that the unit is switched on, ie. the power light comes on, if it doesn't, check your power chord.
  2. If there is power on the unit, but no image/light, check the unit for a fault indicator/light. Cross reference this with your user manual.
  3. If you are unable to verify or do not have a user manual, "google search" your make, model and fault-code, else
  4. approach a sales consultant at your nearest Audio & Visual retailer for advise.
My take is that the lamp has blown and needs replacement. These can be obtained from a Audio & Visual Retailer and can be self-installed with a little technical knowledge.
Everything You Need To Know About Replacement Projector And TV Lamps.
Here is what it looks like and what it typically costs:
multimedia projector lamp life Google Search
Dec 28, 2014 | Office Equipment & Supplies
Some how my screen not coming on. The power is coming to the switch but screen not coming on
Without knowing the make and model, I can offer only general troubleshooting tips.
First off, when the machine is powered on, does the CAPS lock light work? If not, 99% of the time it is not getting past POST (Power on Self Test) and is hardware not initializing correctly, or failed. If this is the case, removed battery, unplug power, and hold power key down for 30 sec to discharge any power in the notebook. Connect battery, plug in, try again.
If the CAPS lock light works, tilt the screen towards a light source (will have to move around quite a bit) and look for a faint image on screen, if you see a faint image, the screens back light is not working, which could be many things (bad connection, inverter for CCFL lamps, bad voltage regulator for LED back lights, etc).
If you feel comfortable, you can try reseating memory, hard drive, wireless card, etc. essentially all the easy to get to components. You can also try deducing it, but removing one at a time...
Hope this helps steer you in the right direction
Good Luck!
Dec 06, 2013 | Computers & Internet
Cannot see thru optics. ifr comes on but still cannot see any image? can the back of the night vision come off to check the power illum light?
Hello, so the image intensifier tube light up. Shake it and listen for parts raddle around inside.
How long have you own this Night Owl? Have you been using night vision on bright lights?
If you have the intensifier tube is gone back to the Red Star....it died! The IR operates on a different switch than the controler, ccfl inverter, multiplier, image tube. Sorry. stewbison
There is good bet that I have a tube for this, but it not worth sending to me. Also, maybe it not the image intensifier tube but something else in the electronic.............Made in Russia--Red Star
Aug 02, 2011 | Night Owl Optics Cyclops Compact NOCC3...
My 15.5 image treadmill lights up but will not start.
I have an Image treadmill model #: IMTL31504.0. It will come on for 1 second and then it appears to lose power. Any thoughts? The belt does run for that 1 second.
Sep 22, 2010 | RTO Image 15.0R Treadmill Walking Belt
Televison & Video Logo
215 people viewed this question
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
