SOURCE: F-17 neovo monitor stopped working. power light is flashing yellow
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
The internal circuits are jammed because of electrostatic charges
accumulating on capacitors, or because of a wrong voltage read by the
main chip on your monitor controller board. this started the protection
circuit.
2 The protection circuit detected a wrong voltage or a
broken contact, identified an internal fault and kicked in , starting
the flashing light.
If you are in situation one, then the
monitor will reset just unplugging power cord for one or two hours,
sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common
faults that can occurr suddenly are a blown capacitor on power board,
the inverter board powering up backlight lamp has blown, or a fault on
main lcd controller board.
check also the video cable, if the cable
is shorting, or the connector is bad, you can get same flashing state
because of the video cable.
Check connectors, try moving the video cable, and if the cable is not built in, then also try a replacement cable.
Regards
SOURCE: Monitor Not Showing A Picture. Light flashes Yellow and Green.
use the onboard graphics instead of a seperate graphics card (if installed) to test the screen.if it still doesn't work then unplug your monitor from the mains supply and plug in again to reset it. i doubt it's your monitor that is the problem though. but look on the back of your pc for another connection for your screen. the onboard graphics connection is normally vertical near your ethernet port and mouse and keyboard inputs.
please rate me and give me a fixya! if it helped.
SOURCE: flashing yellow light on Dell Monitor - what does it mean?
It means the display is in power save mode. This status occurs when the display is on but not receiving any signal.
