Question about Jensen Televison & Video
Need 6 digit parental master unlock code for Jensen TS2050J
Need parental master unlock code for TS2050J Jensen TV
    New Friend:
  • 13 Answers
Http://www.tv-forums.com/forum/TV_Equipment_C4/TV_Repair_Forum_F3/Jensen_TS2050J_Parental_Lock_Code_P26336/
Found a forum with someone who had this issue. Hope this helps
Posted on Nov 28, 2009
6ya staff
SOURCE:
I NEED A REPLACEMENT REMOTE FOR A JENSEN TS2050J WHICH ONE DO I GET AND WHERE DO I GET IT FROM?...............THANKS
You can get a replacement remote here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=TS2050J&uuid=12929864096390 .
Alternatively, you can get a universal remote and try the Audiovox codes if Jensen isn't listed. You may need one of the higher end remotes to match features like changing the source of the TV. (An input/source button will be useful.) Just make sure to check if the remote code does more than turn the TV on and off and changes the channel before deciding that you have the correct code programmed.
I hope this helps.
Dec 22, 2010 | Jensen TS2050J 20" TV
Locked Jensen TV
For anyone who has locked their Jensen TV mistakenly. To unlock it:
1. TV On (Using remote)
2. Press and hold the display button on the remote for about 2 - 3 seconds.
Dec 22, 2007 | Jensen TS2050J 20" TV
All of the sudden my Jenson has a red lock icon in the upper left corner.The TV was given to me so I do not have any sort of lock code set up.
Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will lose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up.
Good Luck,
--Matt
Jun 17, 2010 | Jensen TS2050J 20" TV
Can't unlock Parental lock/w factory reset codes.
I accidentally put on the parental control- to get it off, just hold the display key for about 3 seconds and it should unlock.
Mar 12, 2010 | Jensen TS2750J TV
TS2050J TV (Jensen) locked. How is it unlocked?
Thank you following up. None of the solutions or codes you recommended worked. So I drove to mother's old house and went through things until I found the manual (bedroom bookcase, bottom shelf, under bridge books and old papers). The manual said to hold the display button down 3 seconds. I then drove to mother's new place (assisted living) and tried that. It worked.
Sep 27, 2008 | Jensen TS2050J 20" TV
Universal remote code
I just bought my 2nd remote, it's a phillips SRU3003WM/17 (Walmart) and it actually worked (code - 0914) with the Jensen TS2050J TV I got from a friend. This was the 4th remote I tried.
May 29, 2008 | Jensen TS2050J 20" TV
Locked t.v.!
What is the model number of this TV set? I cannot tell you anything without that as all TV's work in different ways when it comes to locking or parental controls or having to do with the V-Lock.
Jan 04, 2008 | Jensen TS2050J 20" TV
Can't undo the parental lock
try holding "display" on your remote control for 3 seconds.
Sep 01, 2006 | Jensen TS2050J 20" TV
Televison & Video Logo
170 people viewed this question
Top Jensen Televison & Video Experts
Christopher Stearns
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
