Question about Cobra 29 LTD CB Radio
I have a non-lighting Cobra 29 NW face plate, or EL Driver problem . EL Driver is the small metal box mounted inside, to the side, of the the Cobra 29 near the channel selector control . Can anyone tell me where I might obtain a Schematic for the EL Driver . The scielded lead that supplies the ribbon for the face plate seems to have odd voltage, 50v, and some AC, too . I tracked it back to a diode feeding the small IC on the back of the EL Driver . The power feeding the EL Driver, from side mounted transistor, seems okay, 4v-5v . All other leds are acting normally, and controled by the dimmer pot . Besides the schematic, I may need know where to buy a driver, or parts . Is there a test for the face plate ? What voltage is normal for the face plate . Any idea what the parts cost ? Any help will be appreciated on this challenge, Thanks, J
  • Anonymous Dec 06, 2009
    Okay, the El Driver / Inverter tests good(57 - 92 VAC depending on Dimmer position).
    Do I just peel off the old face lighted layer, and the new one will be self-sticking ? I see that the ribbon conductor just slips into the small black bracket connector from a slot near the meter . Seems too easy, wonder what the lighted face will cost ?
    Novelist:
  • Cobra Expert
  • 500 Answers
That is a power inverter. dc to ac inverter. 13-14volts to 40+ volts ac. to run the el display.. if the display is pulled away from the face like the glue is coming loose that indicates the el display is burnt and will not work unless replace the face plate the el face.. you should have 45volts AC on the two wires feeding into the main chassis face to the el display.
Posted on Dec 04, 2009
Testimonial: "Now that I know the EL Driver is an inverter, I have reached that "Ah Ha" moment . Most repair shops won't touch this job, You're good, a true Expert!"
  • AnyMHz.com
    AnyMHz.com Dec 07, 2009
    believe they are. would have to call cobra tech support to order one. think its cobraelec.com then goto there contact page. normally a plugn play repair.
I have a cobra 29 wx nw st cb radio I have power to cb and won't power up
Check for fuse, inside box, as well as outside under the hood. Check your ground wire, not connected...when your groundwire is not making contact to
the body or other metal.. this problem will happen, or your hot wire is not connected to your fusebox...trace your hot wire to see if it is connected, if not connect to fuse box, and this might solve your problem. Hope this help!
Jul 26, 2014 | Cobra 29 LTD CB Radio
How can I fix my cobra 29 nw ltd classic? Everything works but the channel does not display and all I hear is static.
Check TR22 which is a 2sc1957 transistor mounted on side of case near heatsink for driver and final, left rear with speaker cover removed. Make sure the legs are not contacting case. Then check resistors R115, R116, R117 for open circuit and C133 for continuity.
I figure that 2sc1957 transistor is shorting to case or failed. A 2sc2314 is a sub for this transistor.
Oct 01, 2011 | Cobra 29 WX NW ST 40-Channels Base CB...
The lights on the front of my nightwatch is not working but the rest is the meter and channels light up and the dimmer works just the backlighting wont whats the problem thanks
  • That Night Watch face plate is AC ran by a converter inside the radio. The LEDS are part of the face plate and sold as one unit. The face plate goes out often on these radios. In short the face plate needs replaced if you want it to light up. The radio's performance will not be effected by this. Cobra can actually switch that out fairly cheap. Cheaper than buying a face plate used on the net.
  • https://www.cobra.com/index.cfm
Regards, Tony
May 20, 2011 | Cobra 29 WX NW ST 40-Channels Base CB...
I have A cobra 29 NW ST and the illuminated panel is not lighting up. Does anyone know how to repair this?
is it bubbled up? would need a new el face plate, and maybe a new power inverter.. the inverters on those radios do not always work correctly and will short out the el face plate.
Feb 14, 2011 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 29 ltd nw , Backlight face plate does not light .
is the face bubbled pulled away from face? if so need new el plate. if not then check the inverter for correct voltage.
Nov 26, 2009 | Cobra 29 LTD CB Radio
Trying to hook up a astatic echo board
Looking at the plug from inside the radio, with the nub facing downward, from right to left you have pin1 pin2 pin3 and pin4.
1-Shield
2-Audio
3-Transmit
4-Receive
Colors are
1- Red
2-White
3-Blue
4-Black
Mar 24, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Replacing The Cobra 29 Nightwatch Illumination Panel
YOU CAN ORDER THAT PART FROM COBRA ELECTRONICS ON THE INTERNET YOU HAVE TO REMOVE THE FACEPLATE AND UN HOOK THE DRIVET INSIDE THE RADIO IT LOOKS LIKE A SMALL RIBBON CABLE THAT GOES TO THE FACEPLATE. SOME TIMES THE DRIVER ITSELF IS THE PROBLEM. MANY SHOPS JUST DO NOT WANT TO FIX THEM BUT I DO.
Mar 02, 2009 | Cobra 29 LTD CB Radio
No front panel lighting
The "nightwatch" lighting uses an EL or electroluminescent material that does degrade with age. If the radio is old, then it may be lighting very dimly (check in a dark room with the dimmer at full bright). The material is connected by a ribbon to a special high voltage pulsed powersupply that runs at about 500 volt. If the power supply is working then a new face would be in order or a new radio. If the powersupply is not working it may be repairable but requires working with surface mount components. Either way, it is NOT a simple lightbulb fix. I have successfully repaired and do stock the smc components to repair but cannot get the faces through cobra ($$$). More info? Contact through www.cbshop.info
Jan 31, 2007 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 29 LTD CB Radio Logo
991 people viewed this question
Top Cobra Radio Communications Experts
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
