Machine works fine until the final spin. You can hear it pumping the water out. The drum turns once then stops. You can see hear the pump pumping water out. The machine does this for about 5 minutes then clicks to end. The clothes are dripping wet. Have checked pump, motor and brushes.
Any idea?
Motor has broken, the bearing in the motor is screeching and it keep tripping the trip switch
Should you have to use un due force to get the filter undone on the Hoover 1300 special deition washing machine
yes, got a similar problem, m/c runs through it's cycle so far and then programme control starts to spin round (through all wash cycles) eventually completing a spin cycle but leaving the clothes pretty wet. A friend says the programmer is done and needs replacing - looking for someone who has experienced a similar issue with these Hoover CA230 m/c's
Hi i have a CDa c Ci 394 washing machine which brings up the E6 fault code, the water pump is working fine and emptieds the drum of water but the drum does not revolve and after a period of time the fault code comes up, i have checked the motor brushes and they seem fine, any help would be much appreciated
