Router (Netgear WGR614) keeps loosing connection to computer maybe 5 times a week. I unplug it and plug it back in and it connects again, no problem. Any ideas?
It's on the same power strip, but I haven't had the problem up until a few weeks ago. I haven't added any software recently other than Microsoft updates.It's on the same power strip, but I haven't had the problem up until a few weeks ago. I haven't added any software recently other than Microsoft updates.
sure..sometimes the router needs to be on a clean power strip. is it connected to same power strip as printer, by chance?sure..sometimes the router needs to be on a clean power strip. is it connected to same power strip as printer, by chance?
You can't post conmments that contain an email address.
just so i'm clear here..is the connection you are losing a wireless or ethernet direct connection that is dropping?just so i'm clear here..is the connection you are losing a wireless or ethernet direct connection that is dropping?
Check the distance bet computer and the Router.
Donot keep your router near television, microwaveoven or any radio active devces, it may reduce the performance.
Check the Antena terminals for any loose connections.
If possible check your wireless signal strength with another Laptop, to diagnose the router is working fine.
If everything seems to be fine, it maybe the issue with the Adapter.
Goog Luck
Just disconnect the ethernet cable from the computer and put it into the slot called internet on the router then run ehernet cable from port 1 to computer.
The Netgear wireless router wireless settings need to be configured and the the wireless card in the computer needs to be configured with the Netgear wireless settings.
Follow these steps. : - 1. Connect the wireless router to your computer with a LAN cable. 2. Start your browser and enter the router's configuration URL 3. Enter the router setup login and password 4. Change the admin password 5. Go to the wireless settings and change the default SSID and turn off SSID broadcast. 6. Setup encryption key the strongest is WAP2 7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router. 8. Record the settings you have made and keep it in a safe place and Save the settings. 9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router. 10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Reset the router to factory default. Usually done by unplugging the router hold in the reset button and plug in the router wait 30 sec. release reset button Wait 30 more sec. and unplug router again. Then reset your computer to obtain ip address automatically in network properties. Next shut down your computer, router and modem. First re-power the modem, give it time to boot (about 2 to 3 Min. for Cable and dsl or 7 to 10 min for satellite), next re-power the router, again give it time to acquire it's info (about 2 min.) then start your computer and try to access the Internet, all should be well...
Hi there, Here in Denmark, lots of people are well tired of this router. It often loose internet connection, but a hard-reset fix the problem most times. Maybe you just have to unplug the power for a few seconds and then plug it back in, - wait for a minute or two until all the lights are on. If this doesn’t work, please respond, and well find another solution. /Teis
give the dns value in your wireless connection. and after then you see the proxy server is there or not if there then remove it if not there then check it.
-- who is your internet service provider -- what is the operating system of your computer? -- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem
Step 1: Shutdown the computer. Step 2: reset the router while power on then Unplug the router’s power cable. Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds. Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable. Step 5: Plug in the router's power cable once the modem’s lights appear stable. Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
try to reset the router there should be a button underneath or at the back you will need to hold it in for 10 seconds maybe then unplug it then plug it back in see how you get on with that
Running on XP Pro.
Running XP Pro.
This didn't help. Still loosing connection.
Sorry, I forgot to mention it is an ethernet direct connection.
Are you running windows? Vista, XP or Win7
