Sony Playstation 3 (PS3) Console Logo
Anonymous Posted on Nov 28, 2009
PS3 wont play blue ray or PS3 game discs
I need help, my PS3 wont play blue ray discs or any ps3 game discs. I've used all six options on the system from reboot, to restore. issue didn't evolve till last upgrade, about a week ago. Is there any hope for this system? (dvd movie did play, demo download of same game I have on discthat wont play, demo played)
Nanny
Level 3:
Genius:
  • Sony Master 2,351 Answers
  • Posted on Oct 10, 2019
Nanny
Sony Master
Level 3:
Genius:
Answers
2351
Questions
0
Helped
989207
Points
7262
If you want to play Blu-ray disc content on your PS3, you can rip the content first. Leawo Blu-ray Ripper is an easy-to-use Blu-ray to PS3 converting tool to help you rip and convert Blu-ray file to PS3 videos in only a few simple clicks. The below step-by-step guide would tell you the details on how to rip and convert Blu-ray to PS3 videos with Leawo Blu-ray to PS3 Converter.
Jesse Allen
Level 3:
Master:
  • Sony Master 307 Answers
  • Posted on Jun 04, 2018
Jesse Allen
Sony Master
Level 3:
Master:
Answers
307
Questions
0
Helped
161071
Points
1872
It's probably because the blue laser used to read games and Blu-rays have gone bad. You might need to replace it to get your PS4 working again. For playing Blu-rays on PS3, here's a way to do that without replacing the laser:rip and convert your Blu-ray movie to common video files.Here's how: Direct and Indirect Ways to Play Blu Ray on PS3 Respectively
Anonymous
Level 3:
Genius:
  • Master 1,044 Answers
  • Posted on Nov 28, 2009
Anonymous
Master
Level 3:
Genius:
Answers
1044
Questions
0
Helped
184362
Points
3259
Please check the region code on the BD or DVD. It should match the region code set in the system. Otherwise the disc will not play
2answers
Cant play blue ray movie. wants to system update. how does this work
There are some firmwares that support playing movies on the game, if the files are not complete, then the ps3 will not be able to play any movie, and some times it might affect game discs as well.
So when next your playstation 3 wants to system update, allow it, so it will automatically restore the files that are necessary to play a blue ray disc.
Systems update is done online, so you must have an internet connection either wireless or by connection for the playstation, and if it pops up the system update message next time, allow it. It will install new firmwares for the playstation 3 and you will be able to enjoy better services on the game.
Take care and good luck
Hope this was helpful
3answers
Ps3 wont play blu-ray but will play dvd
Maybe your PS3 Blu-ray playback partition has been damaged. But you can convert the Blu-ray to regular video and transfer to PS3 for playback.
Guide on how to convert Blu-ray to PS3 videos:
Step 1: Download and install Leawo Blu-ray to PS3 Converter, and then launch it.
Step 2: Get source Blu-ray movies ready. Insert Blu-ray disc to the Blu-ray drive, or get source Blu-ray folders ready for loading and converting.
Step 3: Load Blu-ray sources
Click "Add Blu-ray/DVD" button on the program interface. This Blu-ray to PS3 converter would then guide you to browse source Blu-ray movies for loading.
Note: After loading source Blu-ray movies, you could select subtitles and audio tracks, play source Blu-ray movies, edit Blu-ray movies, snap screenshots, etc.
Step 4: Do output settings
Next to the "Add Blu-ray/DVD" button, click the dropdown box and select "Change". You will then arrive at the Profile setting panel to select output format from "Format" group or "Device" group. Select "MP4? from "Format" or directly choose "PS3? from "Device > Sony".
Optional settings: After you've set the output format, click the same dorp-down box and click "Edit" option and then you could adjust video and audio parameters of selected profile, including: video codec, audio codec, bit rate, aspect ratio, frame rate, channel, etc.
Step 5: Start converting Blu-ray to PS3
Back to the main program interface, click the green "Convert" button. You could then set an output directory on the right popup sidebar. After setting output dirctory, click the below convert button to let this Blu-ray to PS3 Ripper instantly start converting Blu-ray to PS3 videos.
Note: Internet connection is required during the whole conversion.
After you convert Blu-ray to PS3 friendlier videos, you can transfer the videos to PS3 and then start to play Blu-ray on PS3 in a indirect way. For details, you can read the extension part.
After the conversion is completed, now we should transer Blu-ray movie now in PS3 fridlier video format to PS3 for playing Blu-ray on PS3. Follow the steps below to do so.
Here is a simple step-by-step guide for transferring to or watching video files on your PS3 using a USB flash drive or an external hard drive.
Step 1: Plug a USB flash drive or an external hard drive into your computer and copy over the converted video files that you want to watch on your PS3.
Step 2: After the copying process is done, pull out the USB flash drive or the external hard drive from your computer and then plug it into one of the USB ports on the PS3.
Step 3: Navigate to "Video" on the PS3 XMB menu and find your device, hit triangle to view all contents and select the file you want and either copy it to the PS3 hard drive or just play it directly from the connected device.
By following the guidance above, you can achieve your goal of more safely and conveniently playing Blu-ray on PS3 or watching Blu-ray on PS3 for protecting either PS3 Blu-ray drive or your precious Blu-ray discs from being scratched.
1helpful
MY PS3 will play movies but will not play games?
the blu ray player uses a magnified lens ( likely used in ps3 games too) which is not used when playing ps2 or regular dvds...why they work, any spec or suface wear to the lens will cause the system not to read the discs) , a cleaning disc wont work as the ps3 wont recognize what it is and not play it... only solution i found was to send in for service , which costs @ 150 bucks! I hope this helps
2helpful
3answers
My ps3 won't read ps3 discs but reads ps2 discs
Maybe the factory mixed up the disc readers, and gave yours a ps2 disc raeder
2answers
PS3 wont play games but will play DVD, Blue Ray
You seem to have alot of problems with your console.
1helpful
Ps3 wont read blue ray discs but will read dvd
sounds like the blue ray lens fried, u should be able to find one on ebay or craigs list not hard to put in
Will not play blue ray or dvd
It's a new system glitch you may need to send it in or ake it back and exchange.
1helpful
2answers
My ps3 wont play blue ray discs or my games anymore
if your ps3 doesnt play ANY games or dvds, that may mean that the eye on the ps3(the thing that reads the disks and dvds) is malfunctioning, not moving efficiently enough to procces the disk, not recognizing the encrypted code on the disks, or the optical eye could even be scratched. the disk feed could also not be feeding the disk in far enough for the eye to read it. i would definitly suggest calling customer service and/or bringing the ps3 to an A+ certified technition to "diagnose" your problem.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
