You may have damages a mosfet on the internal amplifier if all the fuses check out.
There will still be power to the unit, but the internal amplifier will not work.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Remove the head unit and check for an inline buss stule fuse on the yellow wire. It may be inside a small black box.
And to check for power - simply unplug the radio and probe the yellow (constant power) wire at the end of the harness.
If there is 12VDC on your multimeter - the problem is in the radio.
If there is no power - the problem is before the radio - typically a fuse. There may be more than one for your radio - depending on your vehicle.
Thanks
There appears to be no power to the unit? No lights on the display or even back lighting to the buttons etc...? Hence I thought it was a power issue?
How can I test it to diagnose the issue?
