Hi there, my acer 22 inch flat screen monitor is having problems staying on. When switched on it stays on for about 20 minutes then the screen goes blank (the switch light stays on). If I switch it off and on again it stays on for about 15 minutes then the same thing happens. If I keep switching it of and on again eventually it won't stay on for more than a minute. Any ideas? Thankyou!
It sounds like there's a problem with the monitor itself. It may be that the lamp in the computer is dying, which would explain why it keeps going out. Other possibility is that the monitor isn't receiving power properly either through the cable or inside the monitor itself.
If your're not the kind of person who wouldn't mind opening the monitor up and hopping in there, then I recommend you take it somewhere it can be diagnosed like Best Buy.
Hope I helped :)
I Have a ACER X223WBD the lamps kept shutting down. The power light would stay blue but the the backlight would turn off. I replace the cfl power supply and the same thing. I CHANGE THE CFL BULBS AND THIS FIX THE PROBLEM. The bulbs are causing some sort of short causing the protection circuit to shut down the backlights.
