Dryers Logo
Anonymous Posted on Nov 28, 2009
Re: Kenmore dryer 110 86983810.
Not heating. I understand I need to check the thermal fuse. 1) is it accessible without removing entire shell
2) should I also replace thermostat at the same time?
thanks,
Sal De
Level 3:
  • Kenmore Master 2,699 Answers
  • Posted on Nov 29, 2009
Sal  De
Kenmore Master
Level 3:
Answers
2699
Questions
0
Helped
1002380
Points
8029
Unplug dryer, no take off bottom panel,use a screw driver or putty knife to remove,there are to clips on top of cover around 2 inches from edge,you'll feel them with tool,push in on them and clips will release, take out lint filter and take off blower wheel duct.clean out lint from duct,now on top of the blower wheel housing you'll see the thermal fuse,part number 3390719,take off one of the wires and read it out with meter,if it's bad change it out,if it's good,pull a wire off of heater and check that and read out the t-stats if you want but i would just change out the part that is bad.also vac out the dryer and go outside and make sure air is blowing flapper open,iblow the vent line out with a leaf blower if it's a long run,you won't believe all the stuff that blows out of there,hope this helps you
1helpful
Where is thermal fuse
If your Kenmore dryer has stopped producing heat, chances are the problem lies with the dryer's thermal fuse. A fire-prevention safety device, the thermal fuse is designed to disrupt the flow of electricity to the dryer's heating mechanisms if the dryer temperature reaches a predetermined maximum. Once activated, the thermal fuse must be replaced to restore the heat to your dryer. In Kenmore brand residential dryers, the thermal fuse will be located in one of two places.
Instructions
Front Panel Access
1 Unplug your Kenmore dryer from its power source. Make sure that the appliance is unplugged before proceeding.
2 Use a flathead screwdriver or putty knife to remove the dryer's bottom service panel, sometimes called the toe panel. Slide the screwdriver or putty knife along the top of the toe panel until you've located the toe panel clips. The clips are usually located about four inches in from either side of the service panel. Push down on the toe clips with the screwdriver or putty knife to release. Remove the panel and set it aside.
3 Locate the thermal fuse on your Kenmore dryer. Look for the thermal fuse directly above the dryer's motor; it looks like a white strip with two wires, and is usually mounted off to one side. See Resources for a diagram of thermal components.
Rear Access
4 Disconnect the Kenmore dryer from its power source while locating the thermal fuse.
5 Move the dryer away from the wall so that you can access the back of the appliance.
6 Use a screwdriver to remove the dryer's back panel. Set the panel and loose screws aside until you are ready to replace them.
7 Locate your Kenmore dryer's thermal fuse just above the exhaust port. The thermal fuse looks like a white strip with two connected wires.
Tips & Warnings
Clogged exhaust ports are a common cause of thermal fuse failure. While you've got your Kenmore dryer in pieces, clean out the exhaust ducts to keep it functioning at its best.
Take all proper safety precautions when working with electrical appliances. Make sure that your Kenmore dryer is unplugged before attempting to service it.
Check this link ,if you use Whirlpool Dryers:
http://www.do-it-yourself-washing-machine-and-dryer-repair-help.com/thermalfuse-dryer-Whirlpool-29inch-electric.html
Thanks
Apr 01, 2012 • Dryers
I have a Kenmore Dryer, Model 96292110. It runs, but it does not heat the air. I have checked the circuit breakers. They are fine.
If your Maytag dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers,thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F.
Thankfully, troubleshooting the thermal fuse in a Maytag dryer is easier than it sounds.
Instructions And Things You'll Needed.
  • Screwdriver,Towel,Electrical tape,Replacement thermal fuse, if necessary.
1 Clean out thelint screen in your Maytag clothes dryer. Lint buildup can cause your dryerto overheat, triggering the thermal fuse to disrupt power to your dryer'sheating mechanisms. Take the lint screen out of your Whirlpool dryer and washit in warm water. Dry the screen thoroughly before replacing it.
2 Look behindthe dryer to check its flexible exhaust hose for kinks or obstructions.Disconnect the exhaust hose from the back of your dryer and clean out any lintthat has built up.
3 Go outside andcheck your Maytag dryer's exhaust vent for obstructions. Lint buildup, birdnests or other obstructions in the outside exhaust vent can trigger yourdryer's thermal fuse.
4 Disconnectyour dryer from its power source before attempting to access its thermal fuse.
5 Access the thermal fuse in your Maytag dryer byremoving the back panel. Remove the screws that hold the back panel in placeand it should easily come free.
6 Look betweenthe dryer's blower housing and exhaust to locate its thermal fuse. The thermalfuse in a Whirlpool dryer looks like a white plastic strip that has two wiresconnected to it.
7 Bypass the thermal fuse in your Maytag dryer whileyou perform a quick diagnostic test. Use electrical tape to tape together thetwo wires connected to the thermal fuse. Reassemble your dryer and plug it backin. Set the dryer to a timed heated drying cycle and press "Start."If the dryer produces heat with its thermal fuse bypassed, it means the thermalfuse needs to be replaced.
8 Replace a blown thermal fuse in your Maytag dryer.Disconnect the power and remove the back panel. Remove the electrical tape thatyou used to perform the diagnostic test and disconnect the wires from thethermal fuse. Remove the screws that secure the thermal fuse to the dryer anddiscard the blown fuse. Attach the replacement thermal fuse by replacing andtightening the screws. Attach the wires to the new thermal fuse.
Thanks for using fixya.
I have voltage to dryer, door switch checks good, start switch checks good, but dryer will not start. What can I check next?
Check the continuity of the thermal fuse located on the blower housing. This thermal fuse is wired in series with the motor and once blown, power to the motor is terminated and the dryer will not start. Also the power to the heating circuit is activated through the motor centrifugal switch. The dryer will therefore not heat once the motor cannot run.
Disconnect power then access the thermal fuse on blower housing.
Dryers with lint filter on the front.
Dryers with lint filter on the top.
You can bypass the thermal fuse for troubleshooting purposes by disconnecting the wires and connecting them together. Insulate the connection properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced along with the cycling thermostat if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
Let us know if you need further advice but indicate the exact model number of the dryer.
2helpful
2answers
No heat and believe it to be the thermal fuse on kenmore dryer 63
Unplug it, remove the back, f73a9b7.jpg1. Hi Limit (small limit upper right hand side of this pic) the most frequent problem if dryer RUNS but no heat AND you have
checked the element and found it to be good. 2. heater assembly.
3. 250f limit (if bad no heat, timer won't advance)
4. heater element
5. Fuse(350F), if blown(open) the dryer will NOT run.
(if you do not have a meter remove and inspect this heater coil for breaks).
6. control thermostat
7. heater (warms thermostat to shut it down faster for delicates)
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
My Kenmore Gas Dryer does not heat. It looks like
You can use an ohm meter to check t-stats and thermal fuse.
Dryer does not heat
YOU NEED CHEK:
GAS DRYER
1-THERMAL FUSE
2-SENSOR FLAME
3-IGNITOR
4-GAS VALVE
ELECTRIC DRYER
1-THERMAL FUSE
2-SENSOR HEAT
3- HEAT ELEMENT
5helpful
2answers
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 • Dryers
Kenmore electric dryer heats but does not dry the
Hi, Here are the obvious parts to check: Heater, High limit, Thermal fuse or thermostats...these are all generally located in the back but some models you access them from front. the most common cause is either heater or thermal fuse, I will include a picture of the thermal fuse. If you test these parts and find they all work you may be looking at a centrifiacal switch problem.
Here is a picture of the thermal fuse check this part first:
http://www.partselect.com/repair.aspx?appliance=dryer&part=replace-thermal-fuse
Please feel free to contact again if you have any other problems.
Hope this helps.
Kenmore 80 series Heating Problem
Most of these issues will need an ohm meter, unless you want to just take a guess.
For Gas dryers.
1. See if the ignitor glows, if not, check the thermal fuse. (if the lint screen is on top, the fuse is accessed behind the back panel, it's small and white, next to the bulkier thermostat. If the lint screen is in the front panel, the thermal fuse is mounted on top of the blower wheel housing, accessed behind the bottom-front or "kick" panel. The fuse should read 0 to .2 ohms at the most, technically is should be zero. If that checks ok, check the ignitor itself, which has a wire harness that connects about 6" from the ignitor. Should be around 50 ohms... a faulty ignitor would read infinite ohms (open).
2. If the ignitor does glow, and you hear a click, but there is no flame, replace the valve coils, (two small cylindrical objects mounted on the valve) Part # 279834. This is assuming your gas is ON.
If Electric, it would not be the fuse, as on electric dryers it is also in the motor circuit, and the dryer would not run at all. Check the heating element, should be around 9-11 ohms. If good, check all thermostats (operating, hi-limit, thermal cutoff). Infinite ohms is bad. Hopefully it's not more complicated than this, or it can get weird..... Hope this helps.
Sep 15, 2008 • Dryers
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
