Question about Hoover Washing Machines
HOOVER SOFTWAVE AUTO WASHER 1000 We have had this m/c for more than 7yrs.During the last 6 mths we have had problems on some progs on the rinse cycle when water leaks out from the soap dispencer tray and runs down the front of the m/c soaking the floor.The water flow is not that high. Can you help please
  • Hoover Master
  • 757 Answers
MMMmmm... WOW this is a 'old puppy'... get your manual here:
http://service.hoover.co.uk/manuals/archived/ac158.pdf
Now go to THIS Link and Page 17
(actual MANUAL page: 29)
Look for "Dispenser Troubleshooting"...
Hoover Soft Wave Instruction Manual Page 17
Then THIS Link for "General Maintenance" as well:
Hoover Soft Wave Instruction Manual Page 14
Anthony
Posted on Dec 24, 2017
Anonymous
SOURCE:
SOURCE: Soap Dispence problem on GHW9200LW
In applications with low water pressure, insufficient water
volume is introduced during the fabric softener dispensing
portion of the cycle to flush the dispenser.
RESOLUTION:
The holes in the dispenser housing were enlarged to allow
a greater volume of water to flow through the fabric
softener dispenser to properly dispense the fabric softener.
Order and replace the dispenser housing, Part
#8181719, to correct the condition
Posted on Feb 03, 2008
Anonymous
SOURCE: lg tromm soap dispencer won't open
sofener cover (blue) cap @ not seated or worn
Posted on Mar 06, 2008
francis rivero
  • 958 Answers
SOURCE: Epic Z - Water coming out the front soap tray
you can try pulling the soap tray out and clean all the old detergent and softener in there. they do clogged the outlet of water for the water to overflow.
check also where the soap box is inserted. it would also have lots of dirt.
tnx 4 using fixya,
drcool
Posted on Oct 19, 2008
Anonymous
SOURCE: Water over flowing in soap dispencer Whirlpool sport duet washer
A sock was in between the two tubs blocking the water going tnto the main tub. This caused the water to backup and overflow in the soap dispencer..and all over the floor I then put my hand in between the two tubs and pulled the sock out. Thanks to the expert group for giving me this solution.
Posted on Mar 20, 2009
john_cross
  • 6277 Answers
SOURCE: Hoover Softwave autowasher 1000; Washer
Could be a couple of reasons- dirty filter and water not hot enough.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
Heater
It could be that the element is coated in calcium. I suggest you run the contents of a couple of sachets of proprietary limescale removing powder/fluid through it. The most efficient way is to put the contents in an empty washer and pour a kettle of hot water into the drum then leave overnight. In the morning run just a spin; the water mix will then go through the drain filter and drain motor impeller blades, doing absolutely NO harm whatsoever, in fact some good!
You could also consider repeating the action ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 12, 2011
Testimonial: "Thanks!"
Hoover softwave not doing anything except clicking
It sounds like the rotating program controller has failed. It is telling other parts of the machine to do things as part of the wash cycle and the signal is not reaching them. This is an expensive part to replace. Get it fixed under guarantee if its new. If its old replace it, but do not buy a Hoover, they are very cheaply made and fail a lot. If you want a cheap one buy a Zanussi.
Dec 20, 2013 | Hoover HC6 110M Front Load Washer
Hi, hoover softwave, noise from drum when turns
sometimes small objects like coins and buttons that came off our cloths makes the noise.See if something would fall if you turn it upside down,that is the simplest thing to do without using a tool.Good luck
Jan 03, 2012 | Hoover AAA140 Front Load Washer
I have a second hand hoover softwave 1100 washer dryer and there are five click switches on the front. I have worked out that the far right one is the power but what are the others for please?
Hello Librimelow,
The Buttons on the Hoover Softwave are as follows from left to right:
1. ?
2. Half load
3. Wool
4. Low Heat
5. Power
I can not find what the first button is I have looked every where I can think of to find out what the first button is. YouTube has many pictures of the front but you can not make out the first button of the group. Sorry I can not be of more assistance.
Thank you for choosing FIxYa.com
Justin
Mar 16, 2011 | Washing Machines
Washing machine off balance in one cycle
Make sure washer is on a level surface and all four feet adjusted properly. A slight forward lean may help with this problem as the out of balance switch is at the rear.
Feb 28, 2010 | Washing Machines
My front-loading Hoover washer/drier (Softwave 1100, Model A8754). Will carry out the wash cycle but not go into spin cycle and thus door will not open. Checked for blockages and none found. Can you help...
Door will not open if it has water in it.
Lay hose down to get rid of water, then you can open door.
Try the spin with no water in, if it spins, then you have a draining problem
Nov 22, 2008 | Hoover Washing Machines
Hoover 550 MA Top Loading Washing Machine
if if spins the belt is ok,may have timer fault or timer module ( next to timer) if fitted will be faulty
Mar 24, 2008 | Washing Machines
My Hoover Model Not listed/stops during the cycle
the cycle timer is beginning to sieze because it needs oil. disassemble washer to the point where you can apply small drops of 30W machine oil to the timer's bearings
May 20, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
606 people viewed this question
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
