My printer is so slow it takes up to 1 hour to copy and print 5 seperate pages why?
Probably insufficient memory on your pc or you are using Norton
go to www.belarc.com and download their Advisor product , it is free
Run it on your machine and it will tell you how much memory is fitted
Windows chews most of a 512mb Ram chip , if you have Norton on then it also grabs loads
2GB is about the norm these days
Try disconnecting from the internet , switch off your Anti Virus and then do print.
Hi VJW,
From what you describe, I'd be leaning toward too much resolution. Try reducing it.
For example, a copy and print at 150 dpi, is four times faster than the same copy and print at 300 dpi (Horizontal x Vertical resolution). If the settings are at 1200 dpi, yes, the process could become quite slow.
Try it. The difference should be notable and immediate.
BEST REGARDS
Mike
