Tiara,
With the limited information you’ve provided about the model type as well the operating system, it may be difficult to ascertain the issues your encountering as well provide you with a reliable solution. Generally when a computer is showing / posting a message as being in sleep mode, it usually means the Operating systems energy savings settings are set to its highest levels. You can modify these settings your self by changing the energy settings in the to a lower level or c
Nothing worked or happened and I am trying to set up my pc
Tiara your post is 1 decade late.
why post ? to relic posts.? are you hyjacking this post? why do that
start your own post with only YOUR facts.
and you will win.
Tiara what PC. do you have make and model.
Compaq ended in 2013, (HP ended this line)
no OS tell what OS you run
and if the fans in the PC blow and can be seen to turn , blow air and make sounds like fan. A laptop has 1 fan,(rare 2)
a desktop has 2 or more. and must not be dead.
turn off sleep in the PC. first.
do the HP hard reset, if PC locks up in sleep mode, covered at HP.com this topic endless.
Tiara (jacker) we have no idea at all what you are attempting , on computers it can do 10,000 things, so what are you doing,?
please start you own post.
post PC model
OS version window?
then state the problem and what works and does not. clearly and answers (expand)
what computers, ? full name and model.
lacking such key facts, hopeless.
the NO SIG means the Monitor brain telling you clear as day the PC video cables are dead, and so be the PC. if cables ok.
Tiara, is it too hard to start your own post
with only YOUR facts and not hyjack
the OPs useless , zero facts post?
case in point, NO PC stated. at all.
no OS stated, at all.
yah.
Try carefully reseating your memory modules and your video card.
