Music Logo
Posted on Nov 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have the first serie MXR Distorsion and the
I have the first serie MXR Distorsion and the gray wire in idlle in the bos I want to know where to sold it
Michial Gueffroy
Level 3:
President:
  • Master 1,140 Answers
  • Posted on Nov 30, 2009
Michial Gueffroy
Master
Level 3:
President:
Answers
1140
Questions
0
Helped
532343
Points
2214
Here is a schematic that may help:http://www.schematicheaven.com/effects/mxr_dist_plus.pdf
What's the wawa employee website login?
talk with the manager as there will be a special site to use along with an employee pass word
MXR phase 90 swtiches on but I have no phasing
I would check the difference in sound between using an AC adapter and a battery. These things lose the effect when the batteries get low.
I nned mxr fullbore pots replacements
Usually with volume pots,the ratings dont matter. you can really buy then anywhere like guitar center,micro center and online. they're really cheap and well worth it.
Audiotechnica atw 3110 with lavalier mic at 898 on wire instrument usualy works fine but on stage wery often sound form instrument with it start to transmit dirty sound some distorsion, like two untuned...
try changing frequencies, also make sure that the mic and the reciever are on the same frequency, what it sounds like to me is that it is set to the adjacent frequency, also be sure the batteries are fully charged.
MY MXR STEREO CHORUS LED LIGHT START TO FADE AFTER CONNECT WITH DC BRICK! DOES THIS MEAN MY PEDAL WILL HAVING ANY DEFECT?
I don't know what you mean by "DC Brick"...
The MXR Stereo Chorus unit requires a special 18 Volt power adapter. The common 9 volt pedal power adapters will NOT work with this device. If you have batteries in the unit, when you plug in an incorrect adapter, the unit disconnects from the batteries and the caps discharge so the light will fade.
You will need to use: ECB-004 18-volt AC Adapter Best to use the manufacture's exact device for this one.
2helpful
How do I fix a mxr phase 90 (overvoltaged!with 12V universal)
My first guess would be that the zener diode is probably shorted. Also check the 2N4125 transistor for a short. Start there and update this with your results.
Dan
MXR Phase 90 doesn't phase only clean signal. The oscillator is working and I have changed the BJT's.
sounds like a switch contact problem, try some surgical alcohol. (for the MXR not for you!!!)
Mxr phase 90 block logo and the 9v power jack not working
These break and SOMETIMES the circuit board gets cracked.
Open up and inspect for damage. If board is cracked, bridge broken traces by soldering wires around the break.
If the solder is broken, resolder it.
If the connector is damaged or weak spring, replace the connector.
Top MXR Music Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a MXR Music Expert? Answer questions, earn points and help others
