My ps3 is hooked up to my tv via HDMI cord. The games will play but if the game is not running my tv says Not supported mode. IE if I try to leave the game to change any network setting the tv doesn't pick up signal properly. Is there a way to fix this.
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release
after the second beep). It should automatically configure your PS3 to
the TV's native resolution for all settings.
Then after that change the output setting to HDMI on your PS3 and see if it works after that, if not, try the system on another TV to make sure its not a problem with your tv.
If it still doesn't work try another cable and then after that it could be a problem with the main board inside of the ps3.
