Question about Sansui HDLCD-2600 26 in. LCD Television
What kind of screws would I need to mount this tv?
  • 11,361 Answers
Metric M5 screw for VESA mount.
Posted on Dec 01, 2009
6ya staff
SOURCE:
How do I install a tv on my wall
First of all find out what size mount is on the TV. On the back of the TV you should see 4 screw holes to take the bolts of the stand. You can measure the space between the holes. Then you can search for a mount that will take that size. If the TV is big you will need a very strong wall mount.
When you get the mount it should have instructions for mounting it. But make certain the wall you are fixing it to can take the weight and is stable. Fix the mount to the wall, make certain that you use the correct screws and plugs for the screws. You should be able to tell if the mount is secure enough. If you have any doubts, get somebody in to do it. The mount will come with the correct fixing screws for the TV. You will need two people at least to fix a smaller TV to the wall and two people to hold a big TV while a third screws the mount to the TV.
Feb 10, 2017 | Televison & Video
Can my tv be wall mounted and is there a special kind of wall mount
Check Walmart , all types / sizes of Wall mounts available
Mar 16, 2015 | Televison & Video
Size of wall mount for GPX LED HDTV
Not sure what you are asking. Are you looking for the screw for the attaching the mount to the TV or the mount to the wall.
If you are looking for the screw size for the back of the TV, it could be metric size M6 or M8. Just be careful of the length. Too long and you will ruin the TV. Maybe google the TV model and it might show in the owner manual the exact screw to use.
Apr 18, 2014 | LG 42LG50 42 in. LCD HDTV
Screw size for 32 inch polaroid
Kindly check the operation manual, if not locate one for free download in websites.
Jul 16, 2012 | Polaroid Televison & Video
Television set is roughly 18 months old and has only recently been wall mounted The picture started to freeze then the following day it wont come off standby Brand EVOTEL
HI, if the problem started straight after the wall mount i would imagine the screws holding your wall mount bracket to your tv are the incorrect ones and will be too long ! this could cause all manner of problems ,on the back of your tv there will be numbers by each mounting hole you can safely use ,these will usually have 8mm or similar written in the plastic ,so use no screws longer than what it states or the tv can break down easily ,check the screws holding your tv mount on ,hopefully it will come right if you put the correct screws in. Thank You for using FixYa
Feb 10, 2011 | Televison & Video
2how to get around large base that sticks out too far to use a low profile mount to mount my magnavox 26MD357B/37 hdtv
Apparently you need some kind of MOUNTING SCREW EXTENSIONS to mount your tv to the wall.
You will need to contact Philips Customer Service at 1-800-705-2000 to order them.
See page 5 of your tv's USER'S MANUAL at the following link:
http://download.m4c.magnavox.com/files/2/26md357b_37/26md357b_37_dfu_aen.pdf
Good luck and please comment back if this was helpful.
Feb 04, 2011 | Philips Televison & Video
I have a wall mount installed already but dont know how to attach the TV - model LA32R71B to it, should I have some bolts or nuts as there are 4 bolt holes in the back of the TV but I dont know the thread...
The wall mounting kit should come with all kind of screws to attach the mounting barckets to the back of the TV. Most TV uses metric M5 or M6 screws for the mounting holes on the back of TV, you should be able to get them at HD or LOWE for about 35 cents each.
My kits come with a bunch of Metric screws. Do you have the instruction sheet of the mounting kit?
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Aug 08, 2010 | Samsung Televison & Video
I have a 37
Metric M5 screws, the wall you buy will be supplying with mounting hardware.
http://www.toptvmounts.com/
http://www.mountsdirect.com/
http://www.mountsmadesimple.com/
Just Google " wall mount for xxxxx"
Nov 24, 2009 | Televison & Video
How do I take the stand off of the TV? (For wall mounting)
There will be clips or screws on the back of the TV which will need to be removed and the base stand will slide out of the bottom of the TV. Do NOT start taking screws out of the back of the TV without the wall mount with instructions. Sometimes there are spacers that need to be used with the wall mount and generally only four screws need to be removed from the TV. The TV should have instructions on how to prepare the TV for a wall mount as well. All are different, but very similar to do. If you lay the TV face down on a soft surface (do not slide it around) you probably can see what screws need to be removed to remove the TV base. Keep the screws with the stand for later use if desired because you will need them to re-install the case later. Here are two examples;
I hope this helps and good luck!
Nov 12, 2009 | Televison & Video
No screws for wall mounting 42 inch tv
any hardware store will have them bring your tv manual with you it will tell you the spec on the screw to connect to the 4 pre existing nuts on the back of the tv as far as from the mount to wall it will be a standard lag bolt small enough to fit threw the hole and long enough to go threw the drywall and about an inch and a half of the studd 2" to 2 1/2" inch lag bolt will work
Apr 14, 2009 | Televison & Video
Sansui HDLCD-2600 26 in. LCD Television Logo
289 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
