The question is that how to change the factory keyless entry code? These methods are to put a NEW PERSONAL entry code not to replace the FACTORY CODE. So please tell us how to CHANGE the FACTORY keyless entry code. If someone could help it would be appreciated. Thanks,,
I followed the instructions to find the factory code behind the fuse box. Yes, that was a pain. But that code does not work. The 8-9 buttons DO lock the car, so I presume the mechanism still works. If the previous owner had personalized the code, the factory code should still work, should it not? And since it doesn't, what is my next step?? Trying to avoid paying $ 150 to the dealer. I am working on this for a 78 year old woman who manages to live on $800 per month, and has nothing to spare.
Thanks In Advance!!
Door pad keyless codes?
in owner manual, enter permanent code and then press "1" and enter personal code, then press "1" again. Then both codes will work.
If you don't have manual, go to Motorcraft.com and click on technical resources and click on your year owner manual.
Each vehicle equipped with a keyless entry keypad is programmed with a five-digit entry code. This code is provided to the customer through a wallet card in the Owner Literature package. In addition, this code is available through a diagnostic tool and is also printed on the vehicle security module label. When entering codes each digit must be entered within five seconds of the previous button press.
Programming/Erasing Personal Code
A unique personal five-digit code can be programmed by following these steps:
The personal code does not substitute for the permanent factory set code. Either code can be used to access the vehicle. In addition, if a second personal code is programmed, it will simply overwrite the previous personal code. To erase a personal code, carry out the following procedure:
The system will now only respond to the factory set code.
Anti-Scan Feature
To provide added security, the keyless entry pad is disabled for one minute after 35 button presses without a valid entry code being entered. The keypad will flash during this one-minute mode with all functionality disabled except for 7/8 and 9/0 still being allowed to lock the vehicle.
Anti-Scan will be turned off after any of the following events:
Unlocking the Doors with the Keyless Entry Keypad System
To unlock the driver door, enter either the factory set code or the personal code (each digit must be pressed within five seconds of the prior digit). The interior lamps will illuminate.
To unlock all doors, enter either the factory set code or the personal code (driver door unlocks) and press the 3/4 control within five seconds.
Locking the Doors with the Keyless Entry Keypad System
It is not necessary to enter the factory set or personal code prior to locking all doors. To lock all doors, press the 7/8 and 9/0 controls at the same time.
Inspection and Verification
SOURCE: Reprograming a keyless remote
program transmitter code(s) as follows:
1) Confirm that all the doors are closed and the ignition key is out of the ignition cylinder.
2) Open the driver’s door. Insert the key and turn the ignition switch to ON position within 10 seconds.
3) Turn the ignition switch to OFF position within 10 seconds, remove ignition key from lock cylin-der.
4) Push and release the driver’s door switch (1) 3 times within 20 seconds.
5) Insert the ignition key and turn the ignition switch to ON position within 10 seconds.
6) Turn the ignition switch to OFF position within 10 seconds, remove ignition key from lock cylin-der.
7) Press and hold both LOCK and UNLOCK buttons (2) on the transmitter (3) for more than 5 seconds
within 20 seconds of removing the ignition key from the lock cylinder in step 6.
8) Press LOCK or UNLOCK button (2) on the transmitter (3) within 5 seconds (after step 7). All the
doors will lock/ unlock to confirm that this process has been properly done.
With this process, the transmitter has been programmed.
9) If you want to program an additional transmitter, repeat the procedure from Step 1) through Step 8).
10) Make sure that the keyless entry system properly operates by operating each transmitter.
SOURCE: reprogram keyless entry system
1991-94 Nissan Maxima key less entry reprogramming procedure:
1. Enter the *original code found under the dashboard.
(*the code begins with the letter F and has 7 digits)
2. Close the doors and lock all of the doors,
enter the 7 digit code
( make sure you have your key in hand).
3. Once the code is entered correctly you will hear a long beep ♪ ♫.
While the beep ♪ ♫ is sounding ... ENTER your NEW 4 digit code, (you will then hear random beeps ♪ ♫)
Do not touch anything until the beeping ♪ ♫ stops.
4. To open the doors, the front windows and the
trunk,
type: S(Clear) and the New 4 digit code and the door will
open automatically.
5. IF by any chance you forget your new code. Just enter the original one and start all over.
