SOURCE: Phillips/Magnavox 9P5544C102 white raster and shuts down
This denotes a problem called blooming the horizontal lines you see are called retrace lines this is caused by the increase in anode voltage which could be caused by an increase in HV section current which trips the overcurrent protection dircuit and turns the TV off.If you do not have electronics experience I would suggest taking the set to a TV repair shop.
SOURCE: Adjusting colors on a magnavox 46" projection TV
Replace the CRT fluid. It grows algea in the blue and green only. 9.99 from MCM electronics.
SOURCE: 55inch. magnavox projection tv. mod.55p8288
sell my the Lenticular Screen (the first screen) or find out what part you need and buy it from me.
danj34 [at] gmail [dot] com
SOURCE: Phillips Magnavox 9P6031C103
Yah go to searspartdirect.com and type in the model number the screen is available after market but is authorized for use by phillips it run about $335 dollars if thats to much check local craigs list or tv shops they sometimes have brokes tvs with good screens
SOURCE: 60 inch phillips magnavox projection tv
CRT coolant change and advanced convergence - how to
I documented the procedure I did on a Philips 55" rear projection 55p916
http://tinyurl.com/lmp6eu
CRT coolant change procedure
http://tinyurl.com/l7bd7r
basic and advanced convergence
