Try different outlets in the house to see if its just one bad outlet.
Also if you get to a know good working outlet plug in the AC Adapter and see if you get the light to come on the adapter. If you do then you know the outlet is good.
If you don't get a the light to come on the AC Adapter, then you know that the AC Adapter is bad and would need to get another one.
If the AC Adapter is good then you know its a problem with the main board inside of the Wii and that would need to be replaced.
my suggestion is you can check once again the connections made in ur nintendo wii........and check whether u pluged corectly...................if the problem persists, you can easily fix this by using repair guide available on net...it will help you to fix this problem.....................
thank you........
all the best..................
click here to download
