SOURCE: Can't connect my Motorola Rokr E6 to my PC
ur window has infected change ur window and install ur data cable into ur pc.
SOURCE: Motorola A1200 Problem
Easy step by step solution!
Hey guys had the same, Try this solution before buying a new battery/charging cable (it might not be the problem):
I did these steps after playing around with it for awhile and am at the stage where my phone turns on fully and says "Battery Charging" when plugged into the charger. It is now charging normally again... Finally! (I had the flashing moto logo too when charger plugged in) I believe this problem occurs because the battery is completely drained and is unable to turn on to charge bcuz the phone needs to be on to be charged, happened to me because i left it in a jacket pocket and forgot about it for weeks. Anyways...
1. You need a USB data cable for it, it should have come with the phone, if not than any USB data cable that fits the phone's charging slot should work (charge cable for the ps3 controller will work or maybe a cable from a digital camera with the same end)
2. Connect the phone to your computer via the USB cable and a USB port that works. Make sure it's plugged in and leave it (even if nothing happens and the screen on the phone is still blank). Although the screen is black, the phone is still charging via your computer (it's just too low on battery to produce the light on the display screen to load up your phone).
3. This might take anywhere between 15 and 45 minutes so be patient and leave it plugged in, beats buying a battery of charger with your money for something that can be solved for free.
4. At some point your computer will make the usual processing noises signalling that it is finally recognizing the phone as a usb device and shortly after your ming's screen will turn on stating that the battery is charging. Success! One of two things will happen, if you have previously installed the ming's drivers to your pc it will just recognize the phone. If you are like me and do not have the drivers installed, you may choose to do so via the cd that came with the phone or just not do it at all.
5. If you want to just charge it via the computer then congrats, your job is done, just leave it plugged in and wait until it is fully charged. If you wish to switch to your regular outlet charger please proceed to step 6.
6. At this point drivers installed or not, either safely remove device from the computer or just unplugg it. Now return your phone to your usual outlet charger making sure its connected. When plugged in you'll notice the moto logo appear (no longer flashing). After about 5 seconds that logo will disappear. At this time flip open the phone. The usual turn on sequence will play out and it will now load up with the battery charging screen similar to the screen from when it was plugged into the computer. Congratulations your phone should be back to normal now.
NOTE: This charge will take longer than your normal charging time but that's just for this time since your battery is super low it will be back to normal after that. Also if this did not work for your phone then now is the time to see if the charger/phone/battery is the problem.
So I hope this helps you out and eases your state of panic. I hope I saved you guys some money with this solution and that your mings are up and running again. I know i was pretty content when the problem was fixed. Please reply with any comments, questions or concerns you may have. Enjoy your once again working mings.
SOURCE: My motorola q doesn't turn on, only shows the
What you need to do is master reset on the cellphone.
You can do it while the cellphone is off.
Press and hold the center bottom for about 5 seconds and inmediately press and hold as well the pòwer bottom both together until you see Master Reset yes or no.
Remember if your performance a master reset all the data will be delete as contacts calendar etc
SOURCE: Motorrokr E6 "Mobile not getting connected to PC"
USB cable is connected between PC and Mobile, Charging is happening. Modem drivers installed. Mobile phone is displayed having Sychronising, phone book, calendar, text message, multimedia studio. On this "initialisation....please wait" is displayed and after some time it displays "mobile not connected".
SOURCE: my motorola Q charger is not charging my battery.
Sir,
It is your PDA battary problem you are suggested to buy new one as by getting charged it cells get weak by the passage of time.
Testimonial: "This was helpful, although i kind of figured that the battery needed replaced."
The Android Wi-Fi Tether application turns your phone into a Wi-Fi hotspot--essentially aMiFi--in one tap. The catch? You have to gain root access to your phone, a multi-step process that uses an unofficial Android add-on which can brick your phone if applied incorrectly. Rooting Android is doable for geeks and hackers with experience soft-modding hardware, but it's not something most users could (or should!) do.
Method 2: Tether Android with Proxoid (Free, no root required, some configuration
If you don't want to gain root but know enough to get around the command line and use proxy servers, the Proxoid Android app can tether your phone for free.
Method 3: Tether Android with PdaNet ($30, no root required, minimal configuration
Finally, the PdaNet Android application lets you tether Android using an app on the phone plus simple software you install on your computer
