Same problem connected to pc now its froze and wont turn off reset does nothing but display the welcome screen etc,,any ideas ?? thanks [email protected]
yes it cycles and thats all it does mate ,its a fuckin nuisance to be honest,,i had a crappy tom tom 1 2 years,,no prob,,yes it cycles and thats all it does mate ,its a fuckin nuisance to be honest,,i had a crappy tom tom 1 2 years,,no prob,,
hey mate,,what a nightmare,,,it took ages to copy what you said etc,,i came home and switch it on and bingo its up and running,,moral of the story,,,dont connect to the pc again hahah,,cheers,,hey mate,,what a nightmare,,,it took ages to copy what you said etc,,i came home and switch it on and bingo its up and running,,moral of the story,,,dont connect to the pc again hahah,,cheers,,
You can't post conmments that contain an email address.
it would be on the bottom where is reset button is, yours might not have one.it would be on the bottom where is reset button is, yours might not have one.
when you push reset does it cycle the unit and comes back to the welcome screen or doesn't even cycle?when you push reset does it cycle the unit and comes back to the welcome screen or doesn't even cycle?
have you upgraded the firmware? http://www.tomtom.com/support/support.ph... have you upgraded the firmware? http://www.tomtom.com/support/support.php?ID=3&Language=1
Connect your TomTom to your computer via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
Copy the Yellow Folders one by one to your PC. Ideally, save all the folders under a new folder that you name.
You may find that the folder ttntools and gns may not be copied. This is o.k. if they aren't.
STEP 2
Format your Tomtom via MY Computer.
STEP 3
Copy the Yellow Folders from the backup you made in STEP 1 back to the TomTom.
STEP 4
Open TomTom Home
Click on Upate Now.
Install the latest update onto your TomTom.
Once installed, switch your TomTom off, then disconnect if from the PC.
Thats it. From now on, make a full backup using TomTom Home prior to any updates.
Also note, that copying all the files will take some time.STEP 1
STEP 2
STEP 3
STEP 4
Open TomTom Home
Click on Upate Now.
need to format the unit and put the folders back, this is the only thing that i know other than sending it back.need to format the unit and put the folders back, this is the only thing that i know other than sending it back.
Well i am writing this wile I am trying this out...
I have a TomTom Go 910 that has a RED CROSS FLASHING on the bottom corner, what I have found is that if you have backed up your TomTom Go i maybe able to reset the TomTom Go on my computer but if you havent you may have to find on try finding one on google but i have a TomTom Go 910 you can download the 910 on http://rapiddigger.com/download/backup-go-910-rar-9110176/.
after you found the back-up you can connect your TomTom Go to your computer using the USB provided from your TomTom Go, replace the doggie file with the new one, then this should change it back to the FIRST update given...
(WARNING >> PLEASE scan the file befor you put it in your TomTom Go it might contain a very very evil virus<< WARNING)
if you can still see and detect it with your pc there may be a newer firmware update to fix this issue try and find the firmware and flashing utility from the manufacturer and see if that helps
Sounds like your firmware is corrupted. I have fixed a few 910's with this same problem. If you have the Tom Tom Home program installed, try to reinstall the firmware using Tom Tom's website.
Make sure you always select to disconnect the device before unplugging it. You might have unplugged it from the PC while it was still writing data. This will certainly corrupt the firmware.
stevi at the back of your tom tom where your windscreen dock goes there is a small rubber bumper if you look to the right and down you will see the reset button it is a small hole above the dock socket. sandy
press the on button then hold the on button the press the reset button, the screen sould flash white, once this is done connect the tomtom to the pc and turn it on then update it via tomtom home
hi,,theres no were i can see were an sd card goes mate ??
there is no were that a card can go in its a tom tom 910 ????
mate,,it was ok till i put it on the pc then,,thats it no go
ok mate,,i let you know how i go on ,,cheers for the help
