I have an old Welbilt chest freezer,it has three lights on front bottom right.Green ,red orange,Green-on,Red-? Orange-Defrost. The orange light will not go off.
Red light lit on freezer means that is not reaches operating temperature.
Most often the old freezer has three indicator lights.
- Green light : that it is brought to a power source and turned on - Red light : means that the temperature is above -18 degrees
- orange light : pressing the so-called SUPER-switch which means that the compressor is running continuously. The SUPER-button switch on a few hours before you begin deep-freeze foods. Freezing time depending on foods quantity (kg). With old freezer must be careful to turn off the switch S (orange light) when the red light goes out or when foods are frozen, otherwise after a few days may burn out the compressor. You should be following the instructions from user manual.
In new freezer managed by the electronics, this function has a predetermined maximum duration, in order to protect the compressor, and can have different marketing names like "shopping".....
if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
defrost cycle is innactive, will ice up shortly and may not turn compressor off, defrost the unit totally(Turn off for 2 days with door open) and remove all water from the unit once done. Restart unit and should work normal for a week or so, ie...defrost cycle...get back to me if this is the case and will sort it from there, [email protected] Russ
the light tell you if the door is closed properly or not . Close the door tightly and check the lights. Then open it and check them again this will tell you the positiopn of the door for each colour
try a total defrost,to clear any internal ice(every 12 months)then switch on and if you have a rapid freeze button leave on for 24 hours to get back to normal operating temp.if you have hard ice around the door seals then you have an air leak which you must sort out(try using a hot cloth to warm seals back into shape.....seals should fit all round, all the time.
Is this just a "Power-on" light to let you know it's plugged in and has power? This is probably just a "neon" (although the actual gas inside is hydrogen for the green color) bulb and sometimes they will do the flickering thing literally forever. In a way it's a good thing as it makes you look at it. If it really concerns you, or if it is actually a warning that something is going wrong (it should say in the manual, you DO have the manual don't you?) have it fixed under the warranty.
I used to sell freezers.the green light tells you the mains is on and the freezer should work.The red light is to inform you the freezer is not low enough temperature,and the orange light is a fast freeze light to over ride the thermostat for use when introducing fresh food.It should not be used for prolonged periods as it may burn out the compressor although in your case you already have a problem and should seek advice or buy another freezer.If you get a cheap freezer thermometer it should confirm what I am saying.
