Most probably a venting problem and probably caused the heating element to ground out in its casing. Easiest way to verify is turn your timer to 30min and if dryer starts heating without pushing the start button you got a bad element caused by bad venting most of the time.
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis electric no heat tip...
Try tossing a tad of dry baking soda in with the clothes in may take a time or two but it would be better than tossing the dryer. If it smells like mildew also maybe try placing some charcoal inside withe door shut, charcoal draws mildew.
Ok but is it making any kind of noise? If it is making a noise then you will need to possibly replace the belt. call your authorize technician to replace the belt and they can also check and clean you lint traps and the insed of the unit.
Cheers
Al
The electric dryer requires 220 volts to dry clothes but only 110 volts to turn the drum .reset your circuit breaker even if it looks ok ,if that dosent work, unplug from the wall and check where the plug wire goes into the back of the dryer and look for loose or broken wires.
HI thanks for your question. the noise you hear , is worn drum rollers or back bearings and front bearings. if you need more assistance get back to me .
try turning the drum by hand...is it jammed? if not, then:
the motor will not turn due to a number of reasons:
1.) simply burned out copper windings
2.) switch not turning on motor or not turning on motor starting circuit-depending on design
...if jammed, then try to find the interference to turning
