Canon PIXMA MX310 All-In-One Printer Logo
Posted on Dec 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error message says paper jam and there is no paper jam all papper removed still not working trun it off then resteated ,no go had it open to check for papper no papper ( open=lifting up maen unit were ink is) help
Colin
Level 3:
Genius:
  • Master 1,584 Answers
  • Posted on Dec 03, 2009
Colin
Master
Level 3:
Genius:
Answers
1584
Questions
0
Helped
469021
Points
4520
Pull plug out of wall for 10 min, replug in and retry.
2answers
Paper jam error
One of the Common error for (Papper Jam) in printer is Error 0x000003eb.
Error code 0x000003eb indicated printer connectivity or printer installation error. If you are trying to install a printer driver but keep getting Error 0x000003eb prompted, make sure you have logged in as the administrator of the computer and then try installing the driver. If the problem still happens, try the below solution steps to solve this problem. The error message doesn't give you much information as it just says unable to install the printer and gives you the error code 0x000003eb.
The Error Message shows you: "Unable to install a printer. Operation could not be completed (error 0x000003eb)"
The printer connectivity or installation error 0x000003eb occurs because the drivers are somehow got corrupted or incompatible.
We know the printer is a very important part of our day to day life. We all need a printer to get hard copies of our important files and documents within a few minutes.
Samsung CLX-3160N Document jam Scanner Error
the printer samsung clx 3160nprinter to check the any papper part .to clear the papper jam then will be the adf scaner sencer hang.so you can change the adf paper senser or correct fix the senserliver. best wishes
When i have no papper in the printer it keeps saying that it is jammed but i checked evrything and there is no papper
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
1helpful
Comes up with paper jam. Open cover, remove drum and removed jammed paper. Had a look no jammed paper, looked at the back fuser area, no jammed paper. Removed paper try, no jammed papper. Can u help
If your printter is showing the message even after you have made sure that there is no paper inside the rollers , it is sure that the sensors- optocouplers- or the input amps for the sensors are defective. Youmay need to check on these individually to confirm. Identify them justt placed beneath the rollers take in guides. Check if thedetector is emitting even without the paper. use a multimeter to check of rvariation of votage with paper or without paper to confirm. hope you try this out and confirm. Good day,
My printer pulls the papper half way to print and then it sound if it was printing but the papper doesn't move i already restarted it unistall the program n reinstall and it still does the same thing
check paper path with test print
right click printer icon go to properties click test print
can you see and remove the jam in paper path Check rollers for slick coating on them they are soft rubber and can get glazed so to speak
remove all parts that you can including paper drawer recheck the paper slot adjustments
sounds simple fix just recheck the paper path for jam or glazed rollers
1 Question ??no error message ?
4helpful
My Documate 152 is saying paper jam but no paper jam
E08 error message which indicates papert jam is caused by lose or mis-alligned input paper tray (automatic document feeder).
Resolve issue by powering off the scanner, opening the paper path section, removing the adf, and then re-seating the adf.
Hp 4250 tn when i try to print get an error 13.05.00 papper never makes it though the fuser
Error message means "Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken."
For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation.
Try cleaning your feed rollers...
There are two types of rollers in printers: hard plastic and rubber. Plastic rollers can be cleaned with alcohol (isopropyl). Rubber rollers can be cleaned with a rubber roller cleaner and restorer like the one in the link (you can find other brands, but make sure its for rubber).
http://www.lmcomp.com/80008.html
2answers
Papper Jamm
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab73
1helpful
2answers
Papper locked in laser printer.
check the back of printer there is a door to remove jammed papers. open it it should flip down and you can easily remove the paper. but switch off the printer before removing paper.
Papper jam.
There should be a door on the back of your printer, scanner, copier. Open that door and see if you have a paper jame there.
old marine
old marine
ZJ Limited
ZJ Limited
