Citrix GoToMyPC Pro for PC Logo
Posted on Dec 02, 2009
Can't detect sound from host computer through gotomypc
Host computer sound is on....remote computer keeps telling me it cannot detect sound on the host computer. I can't hear anything on my remote computer when hooked into gotomypc
Goran Aleksic
Level 1:
New Friend:
  • Contributor 15 Answers
  • Posted on Oct 18, 2015
Goran Aleksic
Contributor
Level 1:
New Friend:
Answers
15
Questions
0
Helped
2177
Points
20
Go into realtek and set it up.
3answers
Unblock facebook.com from our pc administrator
dont need to worry. open anonymouse.org and then enter facebook.com in it. Must vote me and highly rate me. thanks
tip
How To Connect to home computer from Another Location
<p>Using the Remote Desktop feature, you can connect your home computer (host) from any other remote computer (client) and can access all computer resources (installed programs, data and any network resources). You can run any computer application on the remote computer as if you were actually sitting in front of your home computer.<br />Follow the given steps to configure your computer to connect with remote computers: <br />To use this feature, you will need to be logged into your computer with administrative rights. Make sure both computers are connected to the internet. <br />First you have to configure the host computer to allow users to connect to it remotely. On the host computer, right click on "My computer" and click on Properties option.<br />Under the Remote tab, select the option "Allow users to connect remotely to<b> </b>this computer" and click Ok button.<br />Now get the IP address of host computer (type the "ipconfig /all" on the command prompt of host computer to find IP address).Start--Run--type "CMD" then hit enter for command prompt.<br />Now make a connection on remote or client computer, click on Start button, go to All Programs&gt; Accessories, and Communications, then click on Remote Desktop Connection, option. A Remote Desktop Connection, dialog box will appear.<br />Click on Options button for detail configuration, under the General tab, type the IP address of host computer in the Computer box and also type username and password of host computer then click on Connect button to make a connection to remote computer. If your username and password is correct then a remote desktop windows will appear. <br />
on Jul 11, 2011 • Computers & Internet
tip
Connect your home computer from Remote location.
You can run any computer application on the remote computer as you were running actually sitting in front of home computer.
Follow the given steps to configure your computer to connect remote computer: To use this feature, you will need to be logged into your computer with administrative rights.
-To perform this task, first make sure your both computers are connected to the internet.
-First you have to configure the host computer that allows the users to connect it remotely. On the host computer, right click on "My computer" and click on Properties option.Under the Remote tab, select the option "Allow users to connect remotely to this computer" and click Ok button.
-Now get the IP address of host computer (type the "ipconfig /all" on the command prompt of host computer to find IP address).
-Now make a connection on remote or client computer, click on Start button, go to All Programs> Accessories, and Communications, then click on Remote Desktop Connection, option. A Remote Desktop Connection, dialog box will appear.Click on Options button for detail configuration, under the General tab, type the IP address of host computer in the Computer box and also type username and password of host computer then click on Connect button to make a connection to remote computer.
-If your username and password is correct then a remote desktop windows will appear.
Good luck.
on Apr 15, 2010 • Computers & Internet
tip
How to connect your home computer from Remote location?
Using the Remote Desktop feature, you can connect your home computer (host) from any other remote computer (client) and can access all computer resources (installed programs, data and any network resources). You can run any computer application on the remote computer as you were running actually sitting in front of home computer.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
my_computer_properties.jpg Under the Remote tab, select the option "Allow users to connect remotely to this computer" and click Ok button.
remote_desktop.gif Now get the IP address of host computer (type the "ipconfig /all" on the command prompt of host computer to find IP address).
remote_dialogbox.jpg Click on Options button for detail configuration, under the General tab, type the IP address of host computer in the Computer box and also type username and password of host computer then click on Connect button to make a connection to remote computer.
remote_desktop_connection.jpg If your username and password is correct then a remote desktop windows will appear.
on Dec 03, 2009 • Computers & Internet
Need a remote AD 5807a
www.GoToMyPC.com/Control-Computer
or ebay
amazon.com
newegg.com
www.GoToAssist.com/Remote-Control
Out of range H and V after AFTER i USED PARAOGIC DRIVER CURE.
I opened gotomyPC from my laptop and was able to remote access the problem computer.w nt into control panel and reset the computer back to a previous date. it worked
GotomyPC Intermittent connection
had same prob. 3 wired an 1 wireless . wireless would not conn. an others lose connection . after cable upgrade it was in router upgrade changed settings in router i had to call maker of comps an get them to reset ip adds took almost 3 hours to get them all working again they will do a remote access help by useing your ip threw your internet company hope this helps
Top Citrix Computers & Internet Experts
xxxxxx xxx
john h
Are you a Citrix Computer and Internet Expert? Answer questions, earn points and help others
