The TI84Plus has a Shade( function which allows you to represent the area you want to calculate.
The simplest syntax of the command is
Shade( lower_function, upper_function, Xleft, Xright, pattern, patern_resol)
where Xleft is the left limit, Xright is the right limit, pattern is
the shading pattern and pattern_resol is the resolution of the shading.
Only the area where lower_function is less than upper_function is
shaded. Unfortunately this command does give the value of the shaded
area.
To find the area between two curves
Hope it helps.
Thank you for using FixYa.
Do not forget to rate the solution.
Testimonial: "WOW. Excellent"
Actually the simplest syntax for Shade( is
Shade( lower_function, upper_function, Xleft, Xright).
Wether you put in the fnInt( function Y1-Y2, or Y2-Y1 depends on your problem. You do not need to use the X coordinates of the intersection points, just two limits for the interval over which you are calculating the between-curves area.
