Kenmore 24032\24036 Top Load Washer Logo
Anonymous Posted on Dec 03, 2009
Our Kenmore 92274100 washer will not turn.It makes
Our Kenmore 92274100 washer will not turn. It makes a little whining noise and will allow the water to drain, but no movement. Is it a belt problem? Is it too old to fix?
Anonymous
Level 3:
  • Kenmore Master 43,501 Answers
  • Posted on Dec 03, 2009
Anonymous
Kenmore Master
Level 3:
Answers
43501
Questions
0
Helped
10835114
Points
101584
Yes it sounds like a belt. You have made a good diagnosis. Belt are inexspensive, but can be a pain in the rear to install.
You doing the work or someone else??? If it's you then probably fix it. If youare calling in service, then get a price before the person comes and decide if it's worth it.
Also if you are doing it you can find the part online easily.
Do a search for "appliance parts" and then enter your model number in one of the websites.
They will have exploded doagrams so you can see how the belt goes and also a parts menu.
Becareful and check pricing on a number of sites as the prices can vary greatly.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Testimonial: "This makes sense. We'll call a service person to see what they charge but if it's over $75 we'll probably buy a new machine. Thanks."
Should I be able to see water in the tub of my Kenmore 796.4027 washer?
different machine
the water spurts are operating as the drum rotates so that the clothes are evenly wet before the wash process begins
could be designed to use less water than previous models
make sure that the drain hose is at the correct level or all of the water will drain out
talk with a service agent and read the user manual for the operations and what can be expected
3helpful
Kenmore washer makes a whining noise
The whining noise is usually caused by the pump. Try replacing the pump. Or cleaning it out.
My Kenmore washer makes a whining noise while pumping water
This is caused by the pump. Replace or clean out the pump.
Kenmore makes whining noise as it tries to spin
The drive coupling has probably broken. Usually happens when you overload the machine. Easy fix. READ MORE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Kenmore 92274100 washer leaves lint on everything
Be sure to use higher water level on machine, don't overload machine Seperate lint givers from lint attractors. There is a lint catcher mounted on the bottom of the spin basket but it is self cleaning.
1helpful
Kenmore 80 series washer make high pitched whining noise
cold water screen in hose was half plugged causing it to either shut off the spin cylce due to lack of water or increase the spinning speed.
Hope this solves the problem.
1helpful
Whirlpool washer fills up; makes LOUD whine/click metal noise
sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
Kenmore Washer
if whines when filling not pump but fill valve try adj faucet toward off slowly this may reduce noise also be sure all screens are clear ..replacement not necessary if you don't mind noise ..now if noise in pump out remove hoses to pump on bottom remove 2 clips holding pump on remove pump and clean
Kenmore 90 Series Washer Noise--Won't spin
For Tegres
If the noise is only when there is water flowing, check tighten the screws that mount the water fill solenoid valves to the case. The solenoids operate on line current so they vibrate at 60/50Hz (local suppply frequency) if they are loose at all, the noise is loud the body acts as resonators
For SRONEAL, that symptom describes coupling failure exactly, have you removed the coupling to check, often times the motor side hub is stripped, but there is no visible external damage
Washing Machine
turn down water pressure going to the machine and see
Alexander
vince
